...freddy says "under pressure"...
today's work
Ok, wow! So you do the pours with the brass inserts in place already? Gets a perfect seal that way?
Those 'inserts' are temporary: they suspend the soon to be encapsulated O-ring before pouring resin. Once the casting has changed state from liquid to solid the part is extracted from the tool, the 'insert is removed, leaving the O-ring to do its job of making watertight ether an axial running pushrod, or making water tight the union between bulkhead and conduit.
Who is John Galt?Comment
Since I'm mostly a 'skimmer' guy, I'm also working on scaling up a 1/1000 version of the Halifax Class Frigate to 1/144 to make it R/C suitable.
See how it goes. I've got a sample print going right now.
To make a quick and dirty filler you first apply wet CA to the area you want to fill. You then sprinkle on backing soda, (Sodium bicarbonate) over the goo. The high pH of that compound is very high, causing the CA to cure hard almost immediately. You then grind away the excess with rotary tools, files, and sanding sticks.
Like so:
