today's work
    • 13838
    #3646
    David, that JB Weld fast setting epoxy in the picture, so it remains hardened and stable just as slow-setting "standard" epoxy?
    I am not using "5-min" epoxy for it decomposes over time and is not water-stable (UHU Schnellfest).
    Net to get that JBWeld!
    Jörg
    Your point is well taken. The quick-cure epoxy types have a different chemistry than the slow cure stuff. I only use the quick-cure epoxy on non-structural situations, like this decorative hemispherical anchor-light lens atop the TRENCHANT's rudder.
    • DrSchmidt
      • Apr 2014
      • 1367
      #3647
      UV curing resin also works for such apllications....
        • 3621
        #3648
        Also clear sprue from plastic model kits heated on a candle flame or sanded into shape.
          • 13838
          #3649
          TRENCHANT... Finished!!!!
          • SSBN659
            • 418
            #3650
            Haven't been doing any model work for a couple of years now but always look to see what you have been doing. Looks great!
            SSBN659
              • 13838
              #3651
              SSBN659
              Thanks. And good to hear from you, William.
                • 1622
                #3652
                Nice job, Dave, especially on the sail.
                  • 13838
                  #3653
                    • 3621
                    #3654
                    Will this be a master for a grp hull or direct use?
                      • 13838
                      #3655
                      Master -- tools --- GRP, resin and metal parts.
                        • 13838
                        #3656
                          • 3621
                          #3657
                          Tabletop demonstration model for showing how to adjust the ballast vent and blow settings?
                            • 13838
                            #3658
                            Yup. Should wrap up the video by Wednesday.
                              • 3621
                              #3659
                              Cool! Thanks
                                • 13838
                                #3660
