today's work
    • 3472
    #3496
    what scale is the Italian CB again?
      • 724
      #3497
      1/32 scale.
      Here is a identical one in my shop I intend to make a static model of.David RC variant, I ordered two suitable brass props from the Prop shop in preparation for the rc build. Would you like me David to send you one of these props to use as a pattern and add to my model copy? I didn't tell you earlier as I didn't know when you might start project, you said correctly the winter & I know you like to make all your own stuff. Happy to send you if you wish. Click image for larger version  Name:	cb props 1.jpg Views:	0 Size:	49.5 KB ID:	193934
      Click image for larger version  Name:	cb 22 (2).jpg Views:	0 Size:	51.1 KB ID:	193935
        • 3472
        #3498
        Hang a couple of these on the sides.
          • 13632
          #3499
            • 3472
            #3500
            What's up? What are you heating up on the ceiling?
              • 13632
              #3501
              Smart ass!
                • 3472
                #3502
                I see you've glued the side charges to the hull.
                Did you ever consider leaving them whole and removable (magnets). Would make a clean way to hide and reduce needed clean up of hull cut.
                  • 13632
                  #3503
                  Nope..........
