today's work
  • DrSchmidt
    • Apr 2014
    • 1393
    #2026
      • 14013
      #2027
      ****ing biped's! (said a very smug Martian)
        • 14013
        #2028
          • 14013
          #2029
          • Ken_NJ
            • Sep 2014
            • 1006
            #2030
            David, is this XXI you posted the same as this one below? Was going to ask you in email but since you posting those pics.
            Click image for larger version  Name:	IMG_1898.jpg Views:	0 Size:	52.2 KB ID:	178551
            Click image for larger version  Name:	IMG_1897.jpg Views:	0 Size:	50.5 KB ID:	178552
            Click image for larger version  Name:	IMG_1895.jpg Views:	0 Size:	47.9 KB ID:	178553
            Click image for larger version  Name:	IMG_1899.jpg Views:	0 Size:	44.2 KB ID:	178554
            Click image for larger version  Name:	IMG_1894.jpg Views:	0 Size:	50.3 KB ID:	178555
            Click image for larger version  Name:	IMG_1896.jpg Views:	0 Size:	51.2 KB ID:	178556
              • 14013
              #2031
              No, Ken. Two different animals. The one I'm working is 1/96 resin printed (I'm a whore!).
              • Ken_NJ
                • Sep 2014
                • 1006
                #2032
                OK thanks. The one that I have. It's like Skip's Marlin. Styrene with no details on the styrene. Will require lots and lots of scribing to make it look like something more realistic, weld lines etc. Although it has the photo etch which I have not work with before. I think Bob said the kit is from someone in Czech area or someplace around there in Europe? It would be a real challenge to make something of it. Should I accept the challenge in your opinion, or not? If I did it would be on the shelf for a very long while until I finish many many other projects that I have lined up.
                  • 14013
                  #2033
                  It would be a departure from you usual plank-on-frame work, Ken. Do it for the change of pace; one of those shelf-queens you never finish but play with occasionally. You did the MARLIN, so you know what horrors await you with that kit. I would double check the scale of the PE parts before getting too invested though.
                    • Oct 2017
                    • 1121
                    #2034
                    That should be a kit from Oto Gerza/Czech. rcsubs.cz
                      • 14013
                      #2035
                        • 979
                        #2036
                        So Dave, the original kit model is not correct in Scale length? Good catch and praising your integrity to scale.
                          • 14013
                          #2037
                          No 'length correction' here -- I'm not that anal about scale! However, this 1/96 3D printed Type-21 had to be chopped up at the stern as the tail would be hollow cast from resin in a three-piece rubber tool. The forward pieces (once assembled) would be used to make a proper mother-glove tool which in turn would be used to create proper GRP hulls. One for me, and another for Joe Hoffman, who initiated this project. The sail will have its own tool from which thin-walled parts would be laid up.
                          The final tail piece has all the goodies, so had to be tough and hollow. Two propeller shafts, stern planes and linkage, and rudder and its linkage. Tight fit in a small model. The bow planes up front and WTC will be a snap.
                            • 14013
                            #2038
                              • 14013
                              #2039
                                David, I see in the last few photos that you had some orange peel from a clear coat (I am guessing). How do you correct it? Do you sand it out completely or just paint over it? Every once in awhile I get that from rattle cans and it ****es me off. One time it works and then it doesn't.
