Hello David,
Thankyou for the feedback on your gearbox component suppliers. Once again I have a few more questions if you don’t mind.
I am thinking of producing a cylinder design and going down the path that you have pioneered and prototyping all components in Renshape. I am confident I can do this. Then I will make silicon moulds and produce a few. I would eventually like to produce a single shaft and twin shaft endcap.
I have been reading and re-reading anything you have written up about endcap design. I have particularly been looking at your drawings and diagrams. They tell me heaps.
I have spent a couple of hours going over the suppliers websites that you referred to me, Thankyou. However here are the questions, they are rather specific, I hope you don’t mind...
Do you have the actual parts numbers for the spur gears you use, the pinions on the motors and also the cup seals you employ?.
I noticed that you had a bag of seals and oilite bushings, When I was looking at the various suppliers they only seemed to quote for a couple of seals or oilite bushings each. You obviously get a bulk order. May I ask what is a realistic price per unit both seal and bushing?
It is hard for me to gauge how much friction should be imposed on the shaft by the cup seal. As you know I have built my own cylinders and have used seals but don’t know where that threshold is. It is probably something hard to explain. Do you have any wisdom on this?
I have had to think through conversions with inches and millimeters.
Hope you and Ellie had a nice Christmas.
Thanks once again
David H from Oz.
Thanks once again
David H from Oz.
