Japanese Class A 1/16
  • george
    • Dec 2010
    • 731
    #271
    I may be wrong but your post 270 has No pictures showing. All previous ones are visible.
      • 1655
      #272
      The ordered servo's will arrive next week, just in time to replace the dummy servo's i used to get the arragement right, pictures
      I had to make a bracket to house the servo's for the launchtubes, took some stock aluminum plate and bended the right shape, those white strips of evergreen will be used to fasten the servo's.
      Took some broken servo's as a dummy to see at which position they had to be placed.
      Bended the rods for controlling the launchtubes, it's a tight fitt around the control switches but enough room is left for moving them.
      All wires in the rearpart of the SD are in, all connectors soldered and documented which is which.
      Battery pack and levelkeeper are placed inside, made a small charging plug so i don't have to take the battery pack out during charging.
      From left to right, levelkeeper, battery pack and the charging plug.
      For now i have to wait when i have the servo's, when arrived i can start building up the rear bulkhead and the front bulkhead and start testing my contraption.
        • 1655
        #273
        All the delivered servo's are placed, rear bulkhead is finished as is the front bulkhead.
        All cables are tied together with small T raps, i like to keep things tidy, that ESC i ordered some time ago as a test, it can handle up to 10A, BEC 1A, the horns of the servo's are not yet fastened, this will be done when i know the exact position with all channels in neutral.
        I did mentioned about linking up the SAS float at the front , don't want to peel the tube off each time, so i've designed a watertight airplug which i have to make on the lathe.
        This is not needed for the rearpart, i only have to adjust the length of the tubes.
        Before i can start testing the SD i have to take out the SL8 receiver from the 212, don't know why, but my contraption with the old receiver and shadow programmer is dead, in a way it's better, the receiver was allready a bit of a risk.
          • 1655
          #274
          Interesting times are starting here in the Netherlands, today they announced a partial shutdown of the country, She Who Will Be Obeyed was ordered last week to work from home by laptop, we are still well, and hope to stay that way by limiting our social contacts.
          It's a big mess in the Southern part of our country, they expect a second wave to hit this week, which can turn out nasty, i'll keep you guys informed.
            • 14005
            #275
            Hang tight, Manfred. We'll get through this, pal. And Ellie say's hi, to your Boss Lady.
            Stand by for heavy rolls, my friend.
              • 2645
              #276
              I'm wondering at which point the Triffids will turn up?
                • 14005
                #277
                Only a true SF fan would quip that, Andy! Buckets of sea-water on stand-by!
                  • 3768
                  #278
                  I had to look that up.......Triffids
                  Here is a photo of one of our Walmarts.
                  Click image for larger version  Name:	Lodg24KZQOODpi2PUAzPGg.jpg Views:	0 Size:	94.1 KB ID:	137175
                  BUT, the real survival food was not being touched
                  Click image for larger version  Name:	vdoug24ETWyfPwgM3WsWsQ.jpg Views:	0 Size:	108.6 KB ID:	137176
                  That's correct, there were still Snickers!
                  Stay safe Manfred.
                    • 14005
                    #279
                    LOL, Tom. Right on point!
                      • 2645
                      #280
                      They need to make toilet roll snickers. Seems to be what everyone is after at the moment- seems to be priority number one to have something to wipe their arse!
                        • 14005
                        #281
                        Yeah. I don't get the rush-on-****-paper thing. This is not digestive, its pulmonary. Idiots!
                          • 1655
                          #282
                          Thanks for all your comments guys, it made me and SWMBO laugh, which is a good thing, the bad thing is, people are dying here like flies, each time there are more sick people added to the list, they gave us more restrictions, i must say not that heavy as with Bart, the future will learn if our measures will be effective.
                          So, that was the serious part, the bright side is, i've corrected some things at the SD.
                          The SD is now finished and tested, had to replace the receiver and the levelkeeper, added the magnetconnectors and finished up the connections to the rearpart of the sub.
                          Locked down the diveplanes and the rudders for the next step, cutting the rods the right length.
                          I did kept some extra length so i could tweek with them.
                          Taking my measurement for cutting down the rods.
                          After cutting the rods up it revealed that it did not work as intended, so back to the drawingboard, my second attempt made me use bowdencables, this works like a charm.
                          Next step will be. starting up the lathe for my schnorkelconnector, and modify my construction for holding down the resquebouy.
                            • 1655
                            #283
                            Making the connector wasn't that much work, but it's working like intended,
                            This is the tube which is connected to the schnorkel float.
                            Here you can see the airline running to the float, still have to fasten it with some brackets to the hull, that can be done later when i know the exact position of the airline.
                            This is the machined part, used some solid copper rod, drilled it out and made me some grooves inside, those grooves hold the O rings.
                            This was the endgoal, by pushing in the connector i've got me a solid connection, no tools needed for removing it.
                              • 1655
                              #284
                              Reinforced the hook from the resquebuoy and altered the buoy itself with adding some aluminum tubes for easier grip, started on the torpedotubes to get them connected to the SD, pictures
                              Had to take some things apart to make this happen, the hook works now like intended.
                              First step into hooking up the tubes to the SD, added a plastick tube to the magnetic connector to get more stability when hooked up.
                              This how it works, adding the tube gives more stability and the connection will not easely disconnect.
                              Hooked up to one of the tubes, it takes not that much force to make it move.
                              The other side works different without the lever and is a straight forward push movement.
                              For getting the boat under power you need to take off the front part, a easy task with the use of the magnetic connection, for now she is ready and on hold, have to build the testtank in the garden, first want to take the plunge unpainted to see if everything works as intended.
                                • 1655
                                #285
                                Finally some progress and one step closer to the madenvoyage,
                                Builded up the testtank this weekend, filling her up.
                                The first victim to get the plunge, need to get the frontpart off to reach the power switch.
                                Without foam,lead and holes at the bottom, took some time to fill her up, wanted to see where i stand, waterline too high, rearpart nicely compensated by all the foam inside.
                                Testing the thrust of the dual propellor, works like a charm, loads of thrust, David has made this very good scale set of props for this boat, still hate you, rudder will be a issue, much too small to get a responsive turning-rate, have to see what happens in the open water.
                                Scope and antenna floats are in working order, low tech, but most effective.
                                Ballasttank full, plenty of overkill, have to play with foam and lead later on.
                                Resquebouye mechanism works, still have to add the safety wire, but for now i know that it works.
                                Result after a succesfull Saturday, only minor thing was, the rubber seal of the switch wasn't secured that good, got a few drops inside the SD, did a second pressure test after fixing this, no leaks anymore.
                                As you can see the Ko Hyoteki can fitt inside a small suitcase once taken apart, the magnets take care for easy build up and maintenance.
                                Progress on Sunday, drilled the holes with a step drill, these should be enough to get a good result in filling/raising up the boat.
                                Added some lead and foam to get a idea how she stands, the waterline has to become slightly higher.
                                All in all not a bad result, i know now i have to work with a bit of lead to counteract the conningtower, and a lot of foam, she sank to the bottom like a brick, luckely i have enough space inside the hull, and by using multiple radial cuts i can reach easely inside.
                                Have to tinker several evenings to get her tuned in, next step will be testing the torps and finally the maidenvoyage, stay tuned.
