Japanese Class A 1/16
    #286
    Drooling allover.......wow that is one hell of a peice of craftmenship.......I wish I could see this in realtime....darn C19.
    Grtz,
    Bart
    • bassplayer1
      • Mar 2010
      • 244
      #287
      Great work Manfred !!!
        • 3746
        #288
        Manfred, looks great and I enjoy seeing the methodical steps you take!
          • 1647
          #289
          Grtz,
          Bart
          Thanks Bart, now i have to wipe off the slime of my boat, wonder if now the paintjob will hold, C19 will end, time enough to build and meet each other.
            • 1647
            #290
            Thanks Yannis, it was a long run but worth it, hope to get some sticktime soon.
              • 1647
              #291
              Beautiful, Manfred. Beautiful!
              Thanks David, this is the result of both the help of you, Gene and Von, the help with documentation and pictures makes the difference, have to finalise the trimming before i can hit the open water.
                • 1647
                #292
                Thanks Tom,
                Despite i want to run her as soon as possible in the open water i have to keep myself at my checklist, this worked in the past and now, documenting the journey has a advantage, so i can look back how i builded some parts in the past instead of re-inventing the wheel.
                  • 1647
                  #293
                  Finally the heatwave is over, it became that hot inside the cave that my 2K epoxy glue behaved as superglue by setting off like grazy, during the intial trimming i discovered some things which i had to adress first before resuming trimming,
                  Drilling the ventholes at the keel created this problem for me, the trigger of the lower tubes gets hooked into the venthole during pulling off the frontpart.
                  Placed some bars inside the ventholes.
                  A bit crude, but this sub was crude build anyway, giving me two advantages, no big debry can enter and the trigger will slide over the bars without getting stuck into the vent hole.
                  Did today another job of placing the lead to counteract the weight of the tower, used flat lead and curved it conform the hull, the total weight of the tower is 100 gram, the ballast lead is 150 gram, so it should be enough to counteract the tower.
                  When trimming is finished i'll spray the lead with some primer to prefent desolving over the years, i drive in partly sweet/salt water which will affect the lead on the long term.
                    • 1647
                    #294
                    Yesterday the second attempt for trimming, added more foam and lead,
                    Added more foam around the tower, left the same amount at the bow.
                    No sinking like a brick anymore, pretty good, a bit leaning to the left, but that can be solved by shifting the foam near the tower.
                    This is the extra amount of lead and foam, the weight of the extra lead is about 200 grams, which i have to place inside, first i want to do that and then play again with the foam.
                    SD preformed perfectly, no leaks, so back to the cave to glue some lead inside, the total amount will be around 350 gram, i guess two or three times more trimming before the maiden voyage.
                      • 1647
                      #295
                      Thanks David,
                      Yeah it took some more time and effort to get to this point, the conical shape of this sub doesn't help either, splitting her by multiple radial cuts helps, it's pretty easy to get inside for the lead, i will get her running in the wild step by step.
                      As for difficult boat, still have the type 17 in the yard, that boat is a tough SOB, the rear a real nightmare.
                      Take you time with the 212, the MSD is your bread and butter which has to be done first, a man has to eat, as for details i have one rule, if it's possible i'll make it, why?, because it can be done.
                        • 3746
                        #296
                        Which is why when I add some extra detailing to one of my subs, I tell myself that it is time to Manfredize it. Sure enjoy your work!
                          • 1647
                          #297
                          Thanks Tom,
                          Detailling your boat makes it stand out in the crowd, and this japanese puppy will be finished.
                            • 1647
                            #298
                            For now the plate is full with the preparations at the house, building will start after a month or so, i can show you guys what i did last summer and some minor work this winter,
                            Trimming with the new amount of lead inside, she lays straight at last
                            All the foam strapped with elastic bands, yes, sometimes i listen to you David.
                            Aimed to get her slight positive, less than a inch above the surface, good enough for me.
                            Marked down the foam at the hull, the letters where noted down on the foam also to get them at the right place.
                            Stuffed down the foam inside the hull-parts, had to tinker it a bit because the two-shooter gave some problems with fitting the front part, cutted away some foam and replaced a few pieces under the big pieces, front-part fits like a glove.
                            For now she is ready for her maiden voyage this spring, when succesfull i will slap some paint on her and will play around with the torps, crawl, walk and run.
                              • 1647
                              #299
                              Well, this was interesting,
                              I took the Ko Hyoteki for her maiden trip, before launch checked all functions, during her first trip i had no rudder response, due to the wind she got out of course, ended up about 30 mtr from shore, had only forward response on the throttle, only solution was getting her out by swimming, enjoy
                              It all looked good
                              Well this was the result of the first drive, jumped in to get her, she rammed the buoyes marking the deep area and damaged her netcutter, rudder was disconnected from the steeringrods, the netcutter i have to repair, next thing on the list is the steeringrod and poor signal reception, have some homework to do before she can launched again.
                                • 13973
                                #300
                                Idiot! You'll never see me in the water retrieving a toy submarine!
                                Perfection Every Time
