Japanese Class A 1/16
    • 1655
    #241
    Thanks Yannis, it was a pleasure meeting you and get a peek inside your cave, i hope everything is well now?
      • 1655
      #242
      Scope Up!!!, i'm back
      Talking about scope up, made a sidetrack to do a other fellowbuilder a pleasure, he goofed around with building a Bronco Type XXIII, met him a couple of times to see if i could be of help, he made it lately to run his XXIII in the wild, and more important, after diving she resurfaced again, hats off to him.
      He did have one request, wanted to have a scale scope instead of that blob of plastick on a stick, told him i could make this happen, took a scrappiece of aluminum and started turning,
      Stage one, some stainless steel tube, and a scarppiece of aluminum, i did had to recreate the dimensions of my german scope, now archived for the future.
      Coloured the aluminum with a sharpie and marked out the first dimensions.
      Lower part has the right dimension for inside the stainless tube, working on the smallest part which contains the peroscopehead.
      Turning the conical part of the scope, note that the smaller part not yet is to dimension, this gives you room to tweak with the angle of the conical part.
      When the conical part is done you can turn down the smaller part under the head to dimension.
      Finished product, ready for fitting it together.
      As intended the scope slides into the tube with just enough clearance to add some glue.
      To give a impression how big this part is, on my type VII those strange wires are also added, for some reason this was not added at the XXIII's scope.
      Final check if i followed the right dimensions, after this i also added the scopesight and made a lens of epoxy for it, now this scope is his problem.
      You will wonder what about the Ko Hyoteki?, well, between some other issue's i managed to do some stuff, first i solved the minute gap at the tailpiece,
      This was my problem, due to the weight of the rearpart it sometimes wanted to separeate.
      Drilled some 1 mm holes straight through the tubes, added some 1 mm copper false rivets.
      Once pushed into their holes they secure the rearpart, when needed you can take them out.
      to be continued.
        #243
        Order of operations 101, how you going to attack a part…….so important…..nice work Manfred.
        Grtz,
        Bart
          • 1655
          #244
          Thanks Bart,
          Yup, especially when the stock of 6 mm aluminum rods is almost gone, since the lathe was spinning i also made the scope of the Ko Hyoteki, compared to the german scope it's simplicity all over,
          Pretty much the same approach, first measurements and have a go with the lathe.
          For now she's standing like this on the bench, scope ready and the antenna present, next hurdle is, making the resquebouy mechanism, i decided to work from the back to the front of the boat.
          Still have to think about lifting the stuff, probably a KISS float system for both the scope as the antenna.
            • 3768
            #245
            Manfred,
            I gotta say, it is good to see you posting again.
              • 1655
              #246
              Thanks Tom,
              The plate was full with other stuff, have some foundation problems with my house, but that will be taken care of during this year, before i can start with the house build it will take some time, so now it's back to building the Ko Hyoteki to relax.
              The upside of the house story is, if all goes well the Cave will be extended by four time the room i have now (think big cellar), wonder if David will still name it as a Pig-pen, we will see in the future.
                • 14005
                #247
                Originally posted by MFR1964
                Thanks Tom,
                Productivity is disproportionate to shop cleanliness! Structured chaos is good.
                  • 1655
                  #248
                  Blah,blah,blah,blah
                  Last edited by MFR1964; 06-18-2019, 01:43 PM. Reason: forgot one extra blah to annoy you
                    • 1655
                    #249
                    Wanted to build my resquebouye system, but first had to do something else, David stated correctly that the conical shape of the stern would give problems with bouyency, you're not able to get enough foam inside, so i deciced to leave the last part of the stern alone and turned my attention to the second part of the stern.
                    Click image for larger version  Name:	PA070057.JPG Views:	1 Size:	473.0 KB ID:	132802
                    Stuffed in as much foam as i could, used the old ribs to follow the contours of the hull and glued them down with RTV
                    Click image for larger version  Name:	IMG_1642.JPG Views:	1 Size:	96.2 KB ID:	132803
                    The other side of the business end, placed a small spindle inside and added a slidingbar near the hole of the hatch, this is done to give the wire a smooth ride without gettiing stuck.
                    Click image for larger version  Name:	IMG_1643.JPG Views:	1 Size:	97.0 KB ID:	132804
                    A better view on the slidingbar and you can see the hook which will hold the bouye on it's place.
                    Click image for larger version  Name:	IMG_1644.JPG Views:	1 Size:	91.9 KB ID:	132805
                    At the same time i could add the steeringrods with their guides, marked down the exact positions with the SD inside.
                    Click image for larger version  Name:	IMG_1645.JPG Views:	1 Size:	485.8 KB ID:	132806
                    Added the magnets at the last sternpart, this was also done at the second sternpart, when you "magnitize" them together i can control the propellors, rudders, divingplanes and resquebouye.
                    Next little project will be, building the floats for both the antenna and the scope, i've seen some nice examples on the forum and will follow that road.
                      • 14005
                      #250
                      Slowly, but surely coming together. That cone is a SOB to work in, isn't it?! Man, this is going to be one slick looking boat once you've get it into the water.
                        • 1655
                        #251
                        Yeah, it became a bit of a journey, but at the end i get my reward, that cone gave me some grey hairs, took me some effort to get it right, i ended up with the trusty design you allways use when you have a single shaft propulsion.
                        I know there is a guy on Youtube which has a working Ko Hyoteki, has some nice underwater video shots,so i know what the result will be, not sure if he has a working two shooter.
                        Follow the link, https://youtu.be/Hp5wOW73PrU
                          • 1655
                          #252
                          Goofed around this summer with the V80 and the type VII, now it's time to rapport some progress i made last weeks with the Ko Hyoteki.
                          The loose parts to get me a SAS floater.
                          Once put together you get this,
                          Place on the hull at the right position,
                          To make things easy, it's held on it's place by using neodine magnets, easy job for maintenance.
                          Another item on the list that had to be made, added some floats to both the scope and antenna.
                          Had to made some guidingtubes in the upperpart with the hatch.
                          Once placed back, you get this, i like to have my parts removable, you never know when you need to do this.
                          Placed both the antenna and the scope inside, those stainless steel rods are needed to restrict the movement of both devices.
                          I measured up the maximum i could lower the parts untill i reach the SD inside.
                          Extended to their maximum Heights.
                          It barely fitts around the SAS float. here you can see the reserved space between both floats.
                          For now a teaser, working on this contraption to make my two shooter work, iŽll rapport back when there is progress.
                            • 1655
                            #253
                            Made a vid to show how far i got with the rest, also a small demonstration how the scope and antenna will work, if i remember right Tom had made such a contraption with the scope of his Skipjack.
                            Enjoy, https://youtu.be/8MHIb8MO2ZI
                              • 1655
                              #254
                              It took some weeks to complete the launcher and the mechanics, pictures.
                              First i had to adapt the torpedo's, so i could use the lockingmechanisms, ended up with some tubes underneath the torpedo's.
                              Made the hooks which will lock into those tubes.
                              The hooks will fitt inside the tubes like this.
                              Took a spare rear-end and made a green led inside, this is done for adjusting the magnets so you will not burn up your motors.
                              Peeking through the slits i can see when the torpedo is activated by the magnet.
                              Had to change the magnets because the old configuration was too weak to get me a trusty launch.
                              Had to find out at which place the locking device had to be placed, an glued them for the time being with some CA.
                              Those pieces of lead ensure a firm lock inside the topedo's by gravity.
                              Last step was to make some wires attached to both the controle rods and the lockingdevices.
                              Made a vid to show how the whole concept works, enjoy
                              Next week i will have some testing inside the tub, which also will be documented, stay tuned
                                • 14005
                                #255
                                Oh, man! You've made Rube Goldberg proud, sir!
