Thank God for Lexan!
Butter-fingers!!!!!!
You gotta love this guys, last evening i was playing around with the SD, and gravity got hold on it, arrrgh!!!!, frankly said, it rolled of the working bench.
To my delight all three rods in front where bent 90 degrees, so replacing those will be a must, as far i can see no other damage to the SD, i also found out why my torpedo shutters didn't worked properly.
Those little servos have a hard live under my regime, have to replace both, despite i steered them full out, i could push them back without much effort, i guess the motors inside are worn out, probably due to the endless testing of my tubes.
The bright side is, ADF placed at the most sensitive mode, gonna fix those rods and can start all over again with another test drive, man!!!!, you gotta love this hobby!!!!!
Manfred.Leave a comment:
Thanks Tom,
It was a perfect day for the maidenrun, as usual i've got to make some more, but that's all in the game, at least i know she drives good, did my standard drill, also preformed a large 8 figure at some distance to see if there where weak spots in the range, as far i could observe no dead spot for receiving the signal.
At least i´ve got me one torp launched, tomorrow some more testing on the bench, adjusting the ADF and plan another run for some underwater testing.
Congratulations! Good torpedo shot! It looked like a perfect day for a run.Leave a comment:
Phew, the maiden trip has been completed, done some rigurous testing about the range and turningradius, dived several times but i'm not satisfied how things are going, the setting of the ADF has to be changed to more sensitive, i'm going to do this step after step untill i find the right setting.
Turning radius is good enough, about 4 mtr, speed is nice, a little bit overpowered, but that's OK, rudder servo was inverted, easy fix by servo setting change on the transmittor.
I did manage to fire one torp, the other stayed stuck inside the tube, further investication revealed the servo could not open the door enough, i must admit all this was done after a 1,5 hour drive, so right now i'm charging up the batteries, just to see if this influenced the power of my servo's.
If that's the chase i have to fire my torps at the beginning of my drive and not at the end when things are getting on low power, just another lesson learnt.
She Who Must Be Obeyed was so kind to shoot some short vids, enjoy
The last part is about the failed torpedo launch, not yet a vid from driving underwater, but when i've straighten out those things that will be next, first learn more about driving this boat.
Manfred.Last edited by MFR1964; 05-18-2014, 12:02 PM.Leave a comment:
Concrats with your new house, demand at least a bigger workingspace, as for the boat, mine is also trimmed slightly down at the rear when on the surface, more or less accourding to the pictures i have, it seems logical to keep the propellor under water instead of making whipped cream.
I've logged down the remark of gaining more speed when diving, usefull info, the rest will show itself, luckely some hours of drivingtime under the belt from my other boats, let's see if that experience will help, countdown for next sunday.
Great question Manfred. I have mine tail heavy on the surface. So, when I initially want to dive I need to give it just a slight boost in acceleration to allow the leveler to raise the rear up. This allows the trapped air in the very front to find its escape path further aft. After that, I found it to be very easy to maneuver and drive. That being said. Currently, I am still detailing the snorkel and then on to weathering the hull and final assemble (wood gangway attached). Maybe tonight I will get a chance to run it, at least go to Grandma's pool. We put a bid on a house and it just got approved, so if I do not do something this weekend, I will not be able to get anything done for several more weeks.Leave a comment:
Thanks Tom,
Yeah, it's fun torpedoes, to my opinion worth the effort, it was also a good lesson for my type XVIIb, which is next on the list to be completed, she's gathering dust on the wall.
You allready did a good job with your boat, speaking of your boat, how does it drive?, some more knowlegde before my maiden trip is always welcome
Manfred,
i really enjoy what you did with the torpedoes, but also I am inspired to do more on mine. I blame you, but thank you at the same time.
peace,
tomLeave a comment:
Thanks Guys,
As for the know how, allready learned a lot to implement in my type XVIIb, the XXIII turned out to be my testbank for the launchtubes which where intended for my type XVIIb, now i really know it will work.
Shooting torps is still always slick to me, i still get a smile on my face running those grey gremlings around the tub, i know you won't use them every time when you drive your boat, but when needed you can entertain/surprice the crowd.
Counting my days to the weekend, weatherforecast is good, very curious how she will run above and underwater, she will undergo my usual testdrill, and if i'm lucky, She Who Must Be Obeyed will make the vid for me.Leave a comment:
The needed lead is glued inside, she is ready for her maiden voyage, hopefully coming weekend, i also played around with my torpedo system, works like a charm, made some loose vids, i'll compose a new complete vid, which also will include the earlier explanation which i've posted before, be patient, it will take a hour or so to post it on YouTube
I'm nearly there, played a few hours with foam and lead, i wanted to get her as high as possible on the surface, ended up with stuffing the foam under the exhaust cover, and removing some located under the battery hatch.
Balance was OK, but too light to get her submerged, so i added some 54 gram of lead, this will be placed as low as possible to get more stability when surfaced.
This was my aim, it seems she stands high on the waves, but from experience i know she will stand some lower after a few passes underwater, when all parts are wet you can add some extra grams of weight.
Submerged, and some extra bouency, i like to have them slightly positive.
Pictures from the second session, removed the foam under the battery hatch, which was located above the waterline, and added the foam under the exhaust, which is also located above the waterline.
By adding the foam i had to compensate with lead, which i clamped into the floodholes of the tower, at the end it will be located at the keel.
Tried to keep the weight even on both sides.
There is still some room to add the needed lead, the lower the lead the better it is, this way i can compensate the height of the tower when surfaced, she also will be less affected by wind.
The end of a succesfull day, the subdriver preformed excellent, no leaks or moisture, SAS worked like a dream, it's funny to hear each time that slurping sound when surfacing, this week i can fix the lead and make some more sessions to see if she will be ready for the maidenrun.
As for the torpedo system, i give it a go next week, first get this baby ready.
