I took a swift look at the SD, to me it seems that it can be deployed without making it shorter, took one of my launchers in the build, and did some measurements, it can be done, the extra room inside the ballasttank will be usefull since i have a tendency to throw in some extra weight due to the gizmo's.
Talking about the launchtubes, for now i'm busy building them, i'll show you guys the progress sofar.
This is my next generation launchtube for firing electric torpedo's, major difference is, stole the lockingball device from David, and added the magnet on the triggerbar, the launchtubes from my type VII are spring assisted, they push the torpedo out, away from the static magnet which is located underneath the launchtube, now the magnet will slide away, which will trigger the reedswitch inside the torpedo, it's on itself will run under power out of the launchtube.
Did numerous tests to see it it will work flawless, time after time i could launch the torpedo, so that's a winner, the copper tube is designed for my type XVIIb, using this design for the XXIII is a lucky bonus.
Problem with those styrene tubes is, you cannot build up your parts from styrene, they will fail after some time, i decided to build up some components of copper, this tube is ready to be glued.
The second tube is still under construction, at the foreground you can see all components needed.
Inserted one of my electric torpedo's, it's a nice fitt, still have to close the end of the launchtube, preventing the torpedo to be shuffed in too deep.
The tube from the lockingball is a bit to high, that can be easely solved with the dremel, i will follow the same way like David did, will use the length to bent it inwards for preventing that the locking ball will fal out of the tube.
All work in progress, still lots of work to do, have to design the levers which will control the triggerbars, now that i've got the SD, i can make a dryfitt to see how this can be done.
