I allready knew about this site, but you saved me a lot of time searching the pictures by giving me the direct link, thanks again, they are now stored into the archives and will be usefull with building my sub.
And some news from my Skunkworks, last few weeks i couldn't resist to solve the rudder and diveplane steering, at first i tried the wire system, it worked, but there were some issue's, i went back to the drawingboard and copied the original system, pictures.
A three side view of my rudder/diveplane arrangement, used the same system pull/pull for steering the rudder, there is not that much room inside but it's enough for me to make it work.
Deflection of the rudder is about 25 degrees both ways, just like the orignal, this is due to the narrow space you have.
The entire structure can be placed at the back in one piece, once glued tight there will be no maintenance needed, all joints are soldered to maintain this.
Now i have to design a way of connecting the SD magnetic couplers in one move, have to make guides for the propellor shaft and rudder/diveplane connections.
