Excellent.
You're on your way. That ballast tank is sized to counter the displacement of that specific models above waterline structures. That means, by time you have enough foam in there (keep it all just below the designed waterline) to get the top of the sail above the water in submerged trim, that when the tank is dry, the boat will indeed float high, at the designed waterline (the propeller guards above water and the forward waterline below the bow-bouyancy tank limber holes).
Keep at it!
Keep at it!
