Albacore continued
  • Slats
    • 1776
    #571
    Fantastic Mark.....
    now Merriman you bum, finish ASSWIPE up pronto.
    sigpic
      Just got off the phone to Mcmaster&Carr. They are sending out my 3&1/2" tube. Well!.......................its a start
        So, here we go with our new sail. I got it sanded down but I didnt get a picture of that. Im going to do some additional scribing. The grill in the upper rear of the sail to be specific. Nothing extensive.
ID:	93269Click image for larger version
          Also, It has been suggested that I put some LED marker lights on my subs to help maintaining visibility with the submerged sub in dark water. I think that, that is a great idea. However, does anyone have any suggestions as to how to do that? I mean the Skipjack and the Albacore are both about 40" long. It will require mighty small lights to be sure. I thought about fiber optics but that sounds like a lot of trouble. Or using clear sprew of the correct diameter and mounting a light behind it. Any thoughts would be appreciated. If such small LEDs are available, please provide a link. Thanks in advance.
            • 3670
            #575
            Mark,
            how small do you need?
            I have some LEDs I can just send to you.
            tom
              Thanks Tom. Well, they would have to be no bigger outside diameter than 3/32" and that would be too big for scale. True scale would probably be 1/16"
                I just found this. Ill have to look it over.
                Our team at Evan Designs has created this LED size and dimensions chart to help you choose the perfect LED lights for your project. Learn more here and shop today!
                  • 3670
                  #578
                  O.k., 1/16 is about 1.5 mm.
                  i will check my stock and get back with you.
                    • 13628
                    #579
                    Poop or get off the damned pot, Mark. Stop rivet-counting and finish this puppie!
                    You detail-freaks **** me off!
                      • 2503
                      #580
                        I am pooping. A little privacy if you please.
                          I got the sail together and got it primed. We will fill some surface imperfections and squirt it "Charcoal Grey". Then I will make the linkage end for the rudder. Then the Fun part.....getting the old sail off without destroying it.
                            I got in the ready made LEDs that I ordered. (2) green, (2) red and (2) cool whites. They come with a resister inline and shrink wrapped and 14" of wire.
ID:	93427Click image for larger version
Name:	led close.jpg
                            • HvyCGN9
                              • Jan 2013
                              • 187
                              #584
                              Is that about a 1.8mm LED? How do you find them for brightness....? Your Skippy is coming along nicely mate I haven't touched mine since December!! (apart from cleaning it...)
                              Cheers Bruce
                                Bruce, they are indeed 1.8mm. I havent checked yet. Ill do that tomorrow. With the supplied resistor already installed, they are set to run on 6 to 12 volts. Ive already got the 9 volt transistor battery setup that I use in the Seaview. Ill hook it up tomorrow and see about the brightness and report back. Cheers
