Albacore continued
    • 13984
    #346
    OK, smart-ass!...
    ... That's a way, way overdone sonar-window. Don't do it. What was I thinking!?
    (Statute of Limitation has run on those Warrant, by the way!).
    That model was fast as blazes and controllable at all but the very top-end, thanks to the near zero torque produced by the propulsor.
      If you will recall, the original rear bearing came with an extended inner race, for lack of a better term. That race was just perfect for allowing the first prop to push up against it to take the thrust load. However, since that bearing was sealed, I opted for a open bearing. They , however, were not available with an extended inner race. So my solution is pictured here. A thin copper washer that will go between the first prop and the rearmost bearing. I was looking thru my junk hardware collection that I have accumulated for just such a purpose. This time it paid off. The washer had to be a good fit around the shaft to touch just the inner race and not to touch the outer race. Otherwise we would have had unwanted drag. Why am I telling you what you already know? Because I am practicing my Typing.Click image for larger version
        Here we go with the periscope. It is removable. Since it has a good friction fit above and below, itll stay put. Later I will make a radar mast. Now, on with painting the scope.Click image for larger version
          • 3758
          #349
          Coming along nicely - what is your estimate to getting her in the water?
          • Slats
            • 1776
            #350
            Such a great build of such a great little sub.
            J
            sigpic
              Im going to say a couple of months. Considering that I still need a Sub driver for it and I have to finish the cosmetics and trim the boat.
                Patience.........vigilance.
                • Slats
                  • 1776
                  #353
                  looking back at these photos. The boat is very shiny. Are you intending on dulling that paint job down?
                  J
                  sigpic
                    Absolutely. Thats coming up after I finish this little segment.
                      And that little segment is, the representation of the Observation dome on the top front of the sail. Trying to reproduce plexiglass is difficult. What I did was to take flat white as a base and add to it .............Alluminum. As it darkened up I was hopeing that the alluminum would show thru and give the impression of transparency. Well what I ended up with was a medium gray. Oh well , it doesnt look bad. Next I will tape off the silver metal frame around the outside and up through the middle. After the boat is flattened with clear flat I will go back and spray the dome with clear slightly doped with grey to darken it slightly. The airbrush comes in handy for all this.
ID:	68480Click image for larger version
ID:	68481Click image for larger version
ID:	68482Click image for larger version
                        • 13984
                        #356
                        faking windows:
ID:	68484Click image for larger version
ID:	68485Click image for larger version
ID:	68489Click image for larger version
ID:	68490Click image for larger version
ID:	68491Click image for larger version
                        • Slats
                          • 1776
                          #357
                          Nice work
                          David what is your avatar?
                          J
                          sigpic
                            • 13984
                            #358
                            Mr. Caswell is having a little fun with me I'm afraid. (Remember the pink-panties gag?).
                            Grrrrr......
                              • 3758
                              #359
                              HAHAHAHA - your avatar threw me for a loop last night.....That candidate did not seem like a good fit for you.
                                • 13984
                                #360
                                I would be delighted to tell you what I think of that candidate. However, I don't need the secret service in my face today.
