3D printed 1:48 Type VII C in PLA and Resin
  • Wizzard033
    • Sep 2023
    • 41
    Last week I started printing this Type VII C model I found. I used PLA and printed it hollow so that I can fiberglass the interior.
  • Wizzard033
    • Sep 2023
    • 41
    I'm still trying figure out how to post properly here and now I've inadvertently closed the window for attachments and can't figure out how to restore it to finish uploading my pics
    • Wizzard033
      • Sep 2023
      • 41
      • Wizzard033
        • Sep 2023
        • 41
        I still need to reprint the conning tower and guns
          • 3658
          The hull looks O.K. - You are rocking away at this.
          • Wizzard033
            • Sep 2023
            • 41
            It needs quite a bit of prep work before i can epoxy the outside, the model wasn't that great but it would be a good learning experience. I already started making some brass linkage for the dive planes.
            I'm actually very interested in Printing some of the models Bob sells in resin but I wanted to tinker on this one first. I may try printing this one in ABS like resin as well.
              • 3381
              Wouldn't the exothermic reaction of the curing resin cause the the PLA to deform?
              • Wizzard033
                • Sep 2023
                • 41
                I plan to find out. I figured on only applying a 2oz cloth on the interior. I'm going to use Bob Smith 30 minute epoxy.
                if it doen't work this way my 13 year old son has his eye on it even as a static display in his room. He wants to paint and detail a Type VII badly. lol
                I might even try printing it on my resin printer in the same manor
                • Wizzard033
                  • Sep 2023
                  • 41
                  Wouldn't the exothermic reaction of the curing resin cause the PLA to deform?
                  Looks like I have time today to test the epoxy resin on a section of das boot. I'll be back
                    • Jan 2020
                    • 927
                    Where did you find the files?
                      • 3658
                      I recently purchased some Bob Smith 30 minute epoxy, had maybe 12 minutes of working time. Maybe cool the two parts might extend the working time. Just a heads up.
                        • Oct 2017
                        • 883
                        Is that epoxy long term - stable in water, i.e. is it just like 5-min epoxy?
                          • 3658
                          I have not tested it, I believe it is stable in water. I think the short time it spends in water will not impact it and with a coat of paint even less so.
                          • CC Clarke
                            • Aug 2020
                            • 293
                            I've worked with a lot of adhesives in the aerospace world, and this is one of my all-time favorites for slow-cure, 2-part epoxys. This is lab-grade, clear epoxy, which has a 1/2 hour working time, and cures within 12 hours - faster if you use an oven.
                            Hardman makes a five-minute (red label) epoxy, but it can't come close to the (green) label product for low heat generation, high adhesion, and hardness. Excellent stuff.
                            Amazon.com: Tools & More Hardman Double Bubble Green Crystal Clear (Clear as Water) Epoxy 100 Packs (#04004) Model: 4004 : Industrial & Scientific
                            • neitosub
                              • Nov 2021
                              • 145
                              Would be curious to see whether the epoxy-reinforced PLA will warp (or not) under sun exposure. Looking forward to your results!
