3D printed 1:48 Type VII C in PLA and Resin
    • 3681
    #31
    I love it! Bring out the pitch forks and torches. By the way, John Galt was just an engineer.
      • 1937
      #32
      Hi Tom,
      I just wanted to drop you a note to let you know that our thoughts and prayers are going out to you and your wife. My goodness you both are certainly going through a lot lately. Special prayers and thoughts to both of you.
      Rob & Lorraine,
      "Firemen can stand the heat."
        • 3681
        #33
        Thank you Rob and others that have reached out. I appreciate the prayers and support given.
        • Wizzard033
          • Sep 2023
          • 41
          #34
          Sorry for the delays! I haven't had many jobs this year and a really good one popped up so I've needed to repair the head gasket on one of my trucks asap but I will get an update on here soon.
          • jlcrl
            • Oct 2020
            • 24
            #35
            Hello, I have a similar project.
            But waterproof compartment with transparent lexan inspection hatch.
            This improves accessibility.
            I found some informations on plastic/resin adhesion:
            - High tech sub drone 3D printed
            https://www.ingentaconnect.com/conte...pplication/pdf
            page 6 and 7:
            "The epoxy does not seep into and impregnate the plastic, which is the main cause for potential delamination."
            - Also this model maker made an adhesion test:
            CA is used as intermediate layer.
            a thin layer of liquid CA on ABS considerably increases epoxy adhesion
            (tested with 10 Kg weight)
            Another one found that polyester resin on ABS gives correct adhesion (to be tested...)
            • CC Clarke
              • Aug 2020
              • 308
              #36
              Originally posted by Wizzard033
              Wow, you weren't kidding that's a cool product. I might just have to try this as well.
              Thanks, Keith
              Do you know if you can use acetone to thin this epoxy? It makes Bob Smith epoxy very glassy.
              I was first exposed to this product (and other epoxies they make) while working in high rel aerospace applications. We didn't alter it, which is a sure-fire way to have production issues. (Once a production process is locked down, no modifications are allowed without a very compelling waiver.)
              I fill the recesses in my periscope heads with this epoxy to simulate glass - the shinier, the better. Thanks for the tip! I'll give it a try as I just printed a dozen Type 2E and 8B periscope shears yesterday.
              By far, the stongest epoxy I've worked with at multiple contractors is an aerospace-approved, grey 3M epoxy that is sold in syringes. The syringes have to be stored in a freezer, as it begins to cure at room temp. Nobody wanted to use a syringe less than half full as it had been frozen/thawed multiple times. We'd squirt a dab into an aluminum tray to apply and rush the remainder back to the freezer. At some companies, cabosil is added using an approved procedure. After scuffing a metal surface and applying, it would air cure overnight, or we'd use a lab oven to speed it up if it was a priority job. Very difficult to remove without applying heat, (the sworn enemy of epoxy) as the peel and shear force was incredibly strong.
              • Wizzard033
                • Sep 2023
                • 41
                #37
                page 6 and 7:
                I'm interested to look into this. Thanks for the information.
                • Wizzard033
                  • Sep 2023
                  • 41
                  #38
                  thanks for the help, I've been busy lately but plan to continue building subs asap.
                  • Wizzard033
                    • Sep 2023
                    • 41
                    #39
                    Sorry for the delays to all interested I've recently been busy at work but will continue my builds shortly.
