Project 665 Whiskey long bin 1/50
    • Oct 2017
    • 999
    #61
    Scribing, continued. Using a very thin diamond rotary tool and an aluminum strip as a ruler, work progressed qickly.
    Click image for larger version  Name:	20251123_112028_copy_1148x2040.jpg Views:	0 Size:	55.9 KB ID:	192032 Click image for larger version  Name:	20251123_112033_copy_1148x2040.jpg Views:	0 Size:	55.8 KB ID:	192031 Click image for larger version  Name:	20251123_112035_copy_1148x2040.jpg Views:	0 Size:	55.0 KB ID:	192034 Click image for larger version  Name:	20251123_104822_copy_1148x2040.jpg Views:	0 Size:	54.5 KB ID:	192033 Click image for larger version  Name:	20251123_160539_copy_1148x2040.jpg Views:	0 Size:	56.1 KB ID:	192030
      • Oct 2017
      • 999
      #62
      This is the current result of this evening's session:
      Click image for larger version  Name:	20251123_212828_copy_1148x2040.jpg Views:	0 Size:	46.7 KB ID:	192049 Click image for larger version  Name:	20251123_212807_copy_1148x2040.jpg Views:	0 Size:	48.3 KB ID:	192050 Click image for larger version  Name:	20251123_212919_copy_1148x2040.jpg Views:	0 Size:	41.2 KB ID:	192051 Click image for larger version  Name:	20251123_212816_copy_1148x2040.jpg Views:	0 Size:	52.3 KB ID:	192052
      • DrSchmidt
        • Apr 2014
        • 1337
        #63
        Nice work.....
          • Oct 2017
          • 999
          #64
          Thank you, Dr.Schmidt! Doing my best to give that kiddy canoe character!
          Making the four hardpoints for the salvaging device. Styrene was too tiny, went the metal way again! The rings were made from 3mm brass rod that i wound around a 2,5mm core after glowing it soft, cutting the individual rings and flattening them by hammer. I used tubing on the streight part to safe weight. The tip needs to be pointier, this is the first attempt, follow-ons will be made accordingly. After finishing, am confident those will sit fine halfway down in their sockets. That first picture is from a Juliett SSG, slighly different from the shorter and fatters versions of the Whiskeys.
          Click image for larger version  Name:	20251125_153626_copy_1148x2040.jpg Views:	0 Size:	45.0 KB ID:	192124
          Click image for larger version  Name:	20251124_214657_copy_2040x1148.jpg Views:	0 Size:	51.4 KB ID:	192129 Click image for larger version  Name:	20251125_220111_copy_1148x2040.jpg Views:	0 Size:	43.5 KB ID:	192128 Click image for larger version  Name:	20251125_220038_copy_2040x1148.jpg Views:	0 Size:	57.1 KB ID:	192125 Click image for larger version  Name:	20251125_220130_copy_1148x2040.jpg Views:	0 Size:	40.4 KB ID:	192130 Click image for larger version  Name:	20251125_223022_copy_1148x2040.jpg Views:	0 Size:	44.3 KB ID:	192126 Click image for larger version  Name:	20251125_224006_copy_2040x1148.jpg Views:	0 Size:	47.5 KB ID:	192127
          Click image for larger version  Name:	03bef268298a0504d9269e2c9fa72464-pica.jpg Views:	0 Size:	61.8 KB ID:	192118
            • Oct 2017
            • 999
            #65
            Construction continued:
ID:	192157 Click image for larger version
ID:	192159 Click image for larger version
              • Oct 2017
              • 999
              #66
              2nd batch of pictures:
ID:	192161 Click image for larger version
ID:	192162 Click image for larger version
                • Oct 2017
                • 999
                #67
                ...and on deck:
ID:	192165 Click image for larger version
                  • Oct 2017
                  • 999
                  #68
                  More soldering. Made a jig to install the missing posts to the reling sideways of the missile containers. After preparation, the soldering went quickly.
ID:	192241 Click image for larger version
ID:	192236 Click image for larger version
                    • Oct 2017
                    • 999
                    #69
                    First reling is in place! As with the original, the longer posts stand upright on the deck while the fore ones are bend and attached to the side. Some minor corections are necessary, but overall it worked from the start. The positions of the angles were marked over the drill positions and than bend with pliers and fingers. Some trimming back of the ends was necessary to be able to put the reling on.
ID:	192269 Click image for larger version
                      • 13697
                      #70
                      I must say, your work on that sail structure is nothing less than monumental -- what a task. Keep chugging away; keep transitioning this pigs ear into a silk purse. Good work, sir.
                        • Oct 2017
                        • 999
                        #71
                        Thank you, David! Actually i really enjoy the soldering work and am making good progress. Only some easier things left concerning deck details. Am looking forward to having it all ready for permanently gluing it down and priming. When all the floodholes are done on the lower hull, that boat is aiming right for completion!
                        Jörg
                          • Oct 2017
                          • 999
                          #72
                          Changed the reling, it was wrong...Personally, the first approch shown above looks better for my taste, but it is not scale...
ID:	192320 Click image for larger version
ID:	192324 Click image for larger version
ID:	192321 Click image for larger version
ID:	192322 Click image for larger version
                            • Oct 2017
                            • 999
                            #73
                            Second reling is in place:
                            Click image for larger version  Name:	20251203_221221_copy_2040x1148.jpg Views:	0 Size:	57.4 KB ID:	192383 Click image for larger version  Name:	20251203_221232_copy_1148x2040.jpg Views:	0 Size:	56.7 KB ID:	192384 Click image for larger version  Name:	20251203_221210_copy_1148x2040.jpg Views:	0 Size:	60.5 KB ID:	192385
                            Click image for larger version  Name:	20251203_221258_copy_2040x1148.jpg Views:	0 Size:	43.4 KB ID:	192382 Click image for larger version  Name:	20251203_221239_copy_2040x1148.jpg Views:	0 Size:	60.8 KB ID:	192381
                            Click image for larger version  Name:	20251203_221252_copy_2040x1148.jpg Views:	0 Size:	44.1 KB ID:	192380
                              • Oct 2017
                              • 999
                              #74
                              Just finished those last two small relings on the rear hatches of the missile tubes. Hours of finding the proper spot for the best solution between the real boat and my model. At this point, the inaccuracy of the "sail"s geometry had full impact, but now i believe i caught the proper look.
                              Tried grinding the first recess of the salvage couplers, free-handed. Not quite right, yet...
                              Click image for larger version  Name:	20251207_153331_copy_1148x2040.jpg Views:	0 Size:	56.1 KB ID:	192491 Click image for larger version  Name:	20251207_153323_copy_1148x2040.jpg Views:	0 Size:	57.3 KB ID:	192492 Click image for larger version  Name:	20251207_182755_copy_2040x1148.jpg Views:	0 Size:	54.2 KB ID:	192493 Click image for larger version  Name:	20251207_182744_copy_2040x1148.jpg Views:	0 Size:	61.6 KB ID:	192494
                                • Oct 2017
                                • 999
                                #75
                                Second group of pictures:
ID:	192499 Click image for larger version
ID:	192497 Click image for larger version
ID:	192498 Click image for larger version
                                Jörg
