Scratch build Skipjack-conversion : Project 1710 Beluga in 1/63 scale
    • Oct 2017
    • 1015
    #31
Name:	voda_podvodnie_lodki_pr1710_-_beluga_specialnie_podvodnie_lodki_i_apparati-pr1710_01710_makrel_16.jpg
ID:	165530Click image for larger version
Name:	voda_podvodnie_lodki_pr1710_-_beluga_specialnie_podvodnie_lodki_i_apparati-pr1710_01710_makrel_10.jpg
ID:	165531Click image for larger version
Name:	voda_podvodnie_lodki_pr1710_-_beluga_specialnie_podvodnie_lodki_i_apparati-pr1710_01710_makrel_28.jpg
ID:	165532Click image for larger version
Name:	voda_podvodnie_lodki_pr1710_-_beluga_specialnie_podvodnie_lodki_i_apparati-pr1710_01710_makrel_26.jpg
ID:	165533Click image for larger version
Name:	voda_podvodnie_lodki_pr1710_-_beluga_specialnie_podvodnie_lodki_i_apparati-pr1710_01710_makrel_25.jpg
ID:	165534Click image for larger version
Name:	voda_podvodnie_lodki_pr1710_-_beluga_specialnie_podvodnie_lodki_i_apparati-pr1710_01710_makrel_24.jpg
ID:	165535 anyone else having hot pictures of the 1710 please upload 'em!
    • Bob Gato
      • 873
      #32
      Just for Ss&Gs I'd throw the receiver a 4aa battery pack and a servo in the carbon hull on the bench to see how attenuating CRP is to 75mhz ..we all know it wont pass 2.4G but is it truly a block to old school FM.
        • Oct 2017
        • 1015
        #33
        All the same, although its 40mhz in my case.
        • wlambing
          • Nov 2020
          • 389
          #34
          Ah! Safety track!! That could maybe work, if the antenna wire is small diameter enough. Good luck! Still think the 'scope is best/easiest for the application, though.
            • Oct 2017
            • 1015
            #35
            Hi! Though i had only little time to spend building, i managed to apply another coat of (self-mixed) fibre-enforced resin over the filler. After curing i removed larger excess with 80' wet and then placed a strip of 0,5mm styrene over the unfilled hull contour just besides the filler that would keep the distance between sanding block and paper just to make sure i sand down to a continuus radius. I also cut out the styrene "skeleton" for the small passways both sides of the sail that will be pinned into place and backed up with filler and weave.
            Jörg
ID:	165705Click image for larger version
ID:	165706Click image for larger version
ID:	165708Click image for larger version
ID:	165711Click image for larger version
ID:	165707Click image for larger version
ID:	165709Click image for larger version
ID:	165712Click image for larger version
              • Oct 2017
              • 1015
              #36
              More progress :
              The styrene template has been finished and glued with CA to the well-roughened and alcohol-cleaned sides of the sail. Afterwards initiall filling with fine-filler, thinned with a dash of resin. The top coat will be fibre-enhanced filler and maybe some light glass.
ID:	165800Click image for larger version
ID:	165799Click image for larger version
                • Oct 2017
                • 1015
                #37
                Today i continued on the sail. After checking the 1710' pictures i found the deck not blending into the hull but creating a clear edge so there was no more filling over necessary. Instead i ground the filler just back to the outer profile of the template and had the look almost right. Some rinsing with alcohol (not my throat) and pulling along some nitrofiller, followed by some more fine filler. I had some filler left over that went into the fin's fillets. Sail will need to be lowered slightly, after sanding the hull will receive grey primer.
                Jörg
ID:	165815Click image for larger version
ID:	165816Click image for larger version
ID:	165814Click image for larger version
ID:	165813Click image for larger version
ID:	165812Click image for larger version
ID:	165811Click image for larger version
ID:	165810Click image for larger version
ID:	165809Click image for larger version
                  • Oct 2017
                  • 1015
                  #38
                  Nitrofiller applied:
ID:	165822Click image for larger version
ID:	165821Click image for larger version
ID:	165820Click image for larger version
ID:	165819Click image for larger version
                    • Oct 2017
                    • 1015
                    #39
                    Resin filler once more:
ID:	165831Click image for larger version
ID:	165830Click image for larger version
ID:	165829Click image for larger version
ID:	165828Click image for larger version
ID:	165827Click image for larger version
ID:	165826Click image for larger version
ID:	165824Click image for larger version
ID:	165825Click image for larger version
                      • 13834
                      #40
                      Starting to shape up. This thing will go like blazes once you unleash the speed-controller.
                        • Oct 2017
                        • 1015
                        #41
                        Jupp. The grey paint will help spotting uneven areas and symmetrie checking.
                        Cold here, last sunny afternoons so i need to hurry up with the basic resin works. Have to wait until tomorrow so i can finish sanding.
                        Jörg
                          • Oct 2017
                          • 1015
                          #42
                          Fill-grind-repeat.
                          That sail shape is not easy to replicate!
                          A solution to produce even "channels" for the planes to rotate without binding: insert shaft, put over a proper piece of tube and sanding paper and start...grinding.
ID:	166415Click image for larger version
ID:	166416Click image for larger version
                          Bored from all that "grinding", i finished another project: recycling our old kitchen chairs. One was turned into our 3y boy's bench. Another into our 5y girl's gardening table. I made a new stand for my boats.
ID:	166418Click image for larger version
                          My wife got new chairs afterall!
                          Still unsatisfied with that bl***y sail, i made some ingenious papercard templates grom those miserable downloaded sketches i have and had some good deal of grinding-again.
ID:	166420Click image for larger version
ID:	166421Click image for larger version
ID:	166422Click image for larger version
ID:	166423Click image for larger version
ID:	166424Click image for larger version
                          In the end, after inhaling all that nasty dust i came to deciding i cannot have that yunkyard look anymore. Let's paint that thing!
ID:	166427Click image for larger version
ID:	166428Click image for larger version
                          Seriously, the upper hull was roughenend up using 1200' grit and then washed with alcohol. Afterwards, grey primer was sprayed on so i can finally see what i am doing. And blame me, the sail is still wrong!
                          Mr. Merriman, i need some of that unicorn pee!
                          (New sail template already made)
                          Jörg
                            • 13834
                            #43
                            From what was the worst, vile looking collision of varied substrates, glue smears, and tool-marks... emerges a stunning butterfly!
                            The magic of a unifying coat of light-colored primer well demonstrated sir. Invigorating, isn't it?
                            Sure. It still has flaws, but now they are more apparent, and will soon suffer your terrible wrath.
                            The Commie Speed-Demon is coming to life.
                            Go get 'em, Tiger!
                              • Oct 2017
                              • 1015
                              #44
                              Errors identified! More s-curve to the front, more "hunchback" to the stern. Meanwile i found some nice footage:
ID:	166433Click image for larger version
ID:	166434Click image for larger version
ID:	166435Click image for larger version
ID:	166436Click image for larger version
ID:	166437Click image for larger version
ID:	166438Click image for larger version
ID:	166439Click image for larger version
ID:	166440Click image for larger version
ID:	166441Click image for larger version
ID:	166442Click image for larger version
ID:	166443Click image for larger version
ID:	166444Click image for larger version
                                • Oct 2017
                                • 1015
                                #45
                                Sail once more. Will add the transition to the deck after the paint has dried.
                                Click image for larger version  Name:	20221105_144651_copy_1600x1200.jpg Views:	0 Size:	44.6 KB ID:	166462Click image for larger version  Name:	20221105_145751_copy_1600x1200.jpg Views:	0 Size:	36.7 KB ID:	166466Click image for larger version  Name:	20221105_150045_copy_1600x1200.jpg Views:	0 Size:	45.2 KB ID:	166464Click image for larger version  Name:	20221105_153731_copy_1600x1200.jpg Views:	0 Size:	42.7 KB ID:	166467Click image for larger version
