USS Tucson
  • SubICman
    • Jun 2022
    • 87
    #31
    I have some data, however I am not at home at the moment and won't be back there until Wednesday at a minimum. But in general the anchor looks.more like the profile of a propane tank.
    • SSBN659
      • 418
      #32
      I posted 6 photos yesterday but they show up as Unapproved and I don't know why. They show up only when I log in and I can't edit them. Anybody have a suggestion?
      Will Rogers
      SSBN659
      • DrSchmidt
        • Apr 2014
        • 1393
        #33
        Same here....seems the forum software has been updated and now is a bit itch about posting more than one photo
          • 13969
          #34
          There's more to it than that, Doctor. I post a grunch of photos in a single post and don't have any such roadblocks in front of me. However, I think there is a time-limit that might kick in if your writing of the post takes too long? Don't know for sure, but that's the only thing that has held a post of mine in limbo till Bob unlocks the cell door.
          • SSBN659
            • 418
            #35
ID:	167504Click image for larger version
ID:	167505Click image for larger version
            Trying again to post.
              • Oct 2017
              • 1097
              #36
              Nope, no timeout. Odd
              • SSBN659
                • 418
                #37
ID:	167524 Testing the site to see if will take my photo.
                • SSBN659
                  • 418
                  #38
ID:	167526Click image for larger version
ID:	167527 Trying two photos.
                  • SSBN659
                    • 418
                    #39
                    Two medium sized uploads worked. These show how I drilled out the bow underside to insert the brass tubes which were secured in baking soda and CA glue. The photo in my previous post shows where I used Evercoat filler and Bondo glazing putty.
                    Will Rogers
                    SSBN659
                    • SSBN659
                      • 418
                      #40
                      One final post for today. Don't want to push my luck.
ID:	167530Click image for larger version
                      Will Rogers
                      SSBN659
                      • SSBN659
                        • 418
                        #41
                        Finally got some red primer on the underside to check my work. Now layout of the topside details begins and I'll have some questions.
ID:	167672Click image for larger version
                        The first one is what are these openings?
Name:	Tucson docking 2.jpg
                        Will Rogers
                        SSBN659
                        • SubICman
                          • Jun 2022
                          • 87
                          #42
                          Those are limber holes for the free flood area around the vls tubes we call the bath tub.
                          • SSBN659
                            • 418
                            #43
                            Thanks, I assume then they are on both sides. Correct me if I'm wrong.
                            Will Rogers
                            SSBN659
                            • SubICman
                              • Jun 2022
                              • 87
                              #44
                              They are indeed on both sides.
                              • SSBN659
                                • 418
                                #45
                                Too cold to work out in the garage so I've been searching the web and found this shot of the GREENVILLE on dock. These two areas don't show on the drawings I have. What are they?
                                Will Rogers
                                SSBN659
