November Holiday
    "Old fart"? **** you Grandpa!
      • 12326
      Took a closer look on K8 and i now believe the bow planes to be of one piece only, no trim flap etc. i think the line one can see is simply an accumulation of drain holes as the planes are hollow parts. Click image for larger version
ID:	130639Click image for larger version
      I won't question your evaluation of the photos. And, by the way, going negative on the one shot was most revealing. Simple slab type control surfaces they are then.
      • DMTNT
        • Jun 2018
        • 297
        Not to mention creepy looking as all hell! Yikes! But yes, what a clever idea.
        Dead men tell no tales...
          • 12326
          One more propeller question, Scott: What is the diameter of the propeller hub? In other words, what's the outside diameter of the stern tubes? I'm already at work on the blade blanks and soon will have to make the two hubs and dunce-caps so I can start assembling the two propeller masters.
            • 12326
            Scott: just had my 'duhhh moment'. You already gave me the hub diameter: 6mm. Sorry about that. Gotta pay more attention to the posts here.
            The Forgettable
              • 12326
              Scott: I'm deep into the working drawings for the propellers. With a hub diameter of 6mm and a stand-off distance of 3mm between the tip of the dunce-cap and the leading edge of the stern planes this results in a very short hub and dunce-cap combination. Can we get away with only a 1mm stand-off between dunce-cap and stern plane? And I'm assuming your placing the after terminus of the stern tubes aft of the horizontal stabilizer trailing edge the 3mm we see on the plans we're using. Any chance of making that stand off distance 1mm?
              These recommendations posited to keep the hub and dunce-cap assembly from appearing too 'fat'.
              As you can see in the picture of a real FOXTROT, they put the duce-cap tip only inches away from the leading edge of the rudder and stern planes.
              Thoughts, oh great Pattern-Maker from down-under?
                You bet. That will work. I'd sort of intended to use that stern tube extension as a bit of a fudge factor in case I stuffed someting up with the rear geometry in any case so forge ahead, 1mm it is.
                  • 12326
                  Excellent! You just made the propeller look a lot better. Should have good shots of that work tomorrow afternoon.
                    • Oct 2017
                    • 721
                    Did some more digging. How i do it? use google translator, transcription German(English) -> Russian, type "Projekt 627 Nuclear Submarine" -> lots of treasures :-))))
                    .. Построено: 1 / 12..Модификации:.• проект 627 – базовый предсерийный проект первой отечественной ПЛА (1958 г.).• проект 627А – усовершенствованный серийный проект с изменениями (1959 г.) (см. в тексте).• проект П-627А – неосуществлённый прое...
                    Уникальная конструкция и вооружение, первый поход на Северный полюс, катастрофа и вечная стоянка на приколе — ровно 60 лет назад, 17 января 1959 года, советский РИА Новости, 17.01.2019
                      • Oct 2017
                      • 721
                      and some more new pictures (hope i don`t double-post `em) : Click image for larger version
ID:	130668Click image for larger version
ID:	130669Click image for larger version
ID:	130670Click image for larger version
ID:	130671Click image for larger version
ID:	130672Click image for larger version
ID:	130673Click image for larger version
ID:	130674Click image for larger version
ID:	130675Click image for larger version
ID:	130676Click image for larger version
Name:	f_Y3M2MzUxMDMudmsubWUvdjYzNTEwMzQ2Mi81MDcyL0cya2VvVmxVZ3Z3LmpwZz9fX2lkPTc4NTc5.jpeg
ID:	130677Click image for larger version
ID:	130678Click image for larger version
ID:	130679Click image for larger version
ID:	130680Click image for larger version
ID:	130681Click image for larger version
ID:	130682Click image for larger version
ID:	130683Click image for larger version
ID:	130684Click image for larger version
ID:	130685Click image for larger version
                        • Oct 2017
                        • 721
ID:	130688Click image for larger version
ID:	130689Click image for larger version
ID:	130690Click image for larger version
ID:	130691Click image for larger version
ID:	130692Click image for larger version
ID:	130693Click image for larger version
ID:	130694Click image for larger version
ID:	130695Click image for larger version
ID:	130696Click image for larger version
ID:	130697Click image for larger version
ID:	130698Click image for larger version
ID:	130699Click image for larger version
ID:	130700Click image for larger version
ID:	130701Click image for larger version
ID:	130702Click image for larger version
ID:	130703Click image for larger version
ID:	130704Click image for larger version
ID:	130705Click image for larger version
ID:	130706 and some more pictures (hopefully i don`t start double-posting `em) :
                          • Oct 2017
                          • 721
ID:	130708Click image for larger version
ID:	130709Click image for larger version
ID:	130710Click image for larger version
ID:	130711Click image for larger version
ID:	130712Click image for larger version
ID:	130713Click image for larger version
ID:	130714Click image for larger version
ID:	130715Click image for larger version
ID:	130716Click image for larger version
ID:	130717Click image for larger version
ID:	130718Click image for larger version
ID:	130719Click image for larger version
ID:	130720Click image for larger version
ID:	130721Click image for larger version
ID:	130722Click image for larger version
ID:	130723Click image for larger version
ID:	130724Click image for larger version
ID:	130725Click image for larger version
                          and some more pictures (hopefully i am not double-posting `em)
                            • Oct 2017
                            • 721
ID:	130728Click image for larger version
ID:	130729Click image for larger version
ID:	130730Click image for larger version
ID:	130731Click image for larger version
ID:	130732Click image for larger version
                              • Oct 2017
                              • 721
                              and some more...
ID:	130735Click image for larger version
ID:	130736Click image for larger version
ID:	130737Click image for larger version
ID:	130738Click image for larger version
ID:	130739Click image for larger version
                                • Oct 2017
                                • 721
                                and some more... Click image for larger version
ID:	130742Click image for larger version
ID:	130743Click image for larger version
ID:	130744Click image for larger version
ID:	130745Click image for larger version
ID:	130746Click image for larger version
ID:	130747Click image for larger version
