    Listening to Dad go ballistic as he worked on the ALUMINAUT kit must have traumatized the poor kid for life.
    • crazygary
      • Sep 2012
      • 610
      #62
      Sam sounds a little like my youngest grandson. Likes to run whatever I've built, but not into learning how to do it
      for himself!!
      Loves to "play" with my finished "targets", but not interested in the "blood-sweat-and-tears" part!! However, "You can build one for me if you want, Grampa!" Instant gratification me thinks?? Hah!!
      Kinda like those who prefer non-alcoholic brew!! " All the prestige; non of the committment"!! ( Absolutely no offense intended to those who partake of such a beverage! ) Just not me bloody cup o' tea!!?
        HAHAHAHA, maybe......
        Gary, if anyone has hurt his enthusiasm it is me. My patience is short when Sam asks for help, but then does the opposite. He is smart and that gets him in trouble.
        I have a lot to post and will do it in sections. Got the WTC wet and the hull wet. lots of stuff to cover. So here is just some photos of putting in the pushrods.
Name:	Bronco Type 23_170.jpg
ID:	89260Click image for larger version
Name:	Bronco Type 23_171.jpg
Name:	Bronco Type 23_172.jpg
ID:	89262Click image for larger version
Name:	Bronco Type 23_173.jpg
Name:	Bronco Type 23_174.jpg
ID:	89264Click image for larger version
Name:	Bronco Type 23_175.jpg
Name:	Bronco Type 23_176.jpg
        Sorry got to go to dinner..... more later tonight. Might be able to trim tomorrow.
          The prop shaft is fun for me. I like the way it snaps apart when you scribe a line around it with a blade.
          To recap, scribe line all the way around by rolling it on the edge of an x-acto blade.
Name:	Bronco Type 23_177.jpg
          Then bend the pipe and it will split on the scribe.
Name:	Bronco Type 23_178.jpg
          Nice clean break.
Name:	Bronco Type 23_179.jpg
          The nylon ends from the Dumas drive coupler get pinned into the aluminum tube.
Name:	Bronco Type 23_180.jpg
          A view of the drive shaft installed.
Name:	Bronco Type 23_181.jpg
          I mentioned I water tested the Sub-Driver no leaks, but two issues popped up.
          The first was one servo froze up. The second was the pump made strange noises and would not run.
          The solution for the first issue was replace the servo - no biggie there.
          The solution to the pump was not so clear. It was touching the aluminum bulkhead, so I was guessing it was shorting somehow.
          Placed a rubber pad as an insulator and put rtv silicon down to hold the pump and a zip tie to secure it.
Name:	Bronco Type 23_182.jpg
ID:	89284Click image for larger version
Name:	Bronco Type 23_183.jpg
          Created an extension to the float. Still playing with it.
Name:	Bronco Type 23_184.jpg
          Glued the aft end mount.
Name:	Bronco Type 23_185.jpg
          It stands a bit proud and will need to be trimmed down.
Name:	Bronco Type 23_186.jpg
          The forward mount fits like a glove.
Name:	Bronco Type 23_187.jpg
            The front mount fits like a glove is true, but it should have been shaved down a bit before installing. There is a small raised area the conning tower straddles. The front mount prevents the front edge of the tower from reaching the hull.
Name:	Bronco Type 23_188.jpg
            I carved out the mount to accommodate the raised area.
Name:	Bronco Type 23_189.jpg
            Now the front mates up to the hull.
Name:	Bronco Type 23_190.jpg
            Installed the tabs. Like a zipper the tabs are alternated with more to the aft end because if the bends there.
Name:	Bronco Type 23_191.jpg
            The forward tabs on the top dec were cut to angle the sides, this allowed the piece to drop down and start the securing of the deck.
Name:	Bronco Type 23_192.jpg
            The forward edge of the deck piece, a rectangle of styrene is installed to be the tab that will slide under the bow end of the lower piece.
Name:	Bronco Type 23_193.jpg
            The aft end is secured with a screw and mount. First loosely measured were I wanted to drill and assembled the two hull pieces together. Then drilled straight down through the deck piece and the lower hull piece. Again, I should have made the tab stick out a bit more, but the drill did pierce the upper deck and through the tab (barely). The mount is CA'd in. Then I put some baking soda (sodium bicarbonate) and CA round the mount to build up the area and make the mount more secure.
Name:	Bronco Type 23_194.jpg
            • crazygary
              • Sep 2012
              • 610
              #66
              K.I.S.S. engineering on the fly!! Way to go, Tom!!
              You guys are "The Bomb"!!
              Thanks so much for these great thought-provoking posts!
              Looking forward to her eventual completion!!
              • crazygary
                • Sep 2012
                • 610
                #67
                Tom and all-
                Just had a thought as far as small quantities of lead shot for ballasting:
                SCUBA diving soft weights! Usually in 1,2, 4 lb. sizes! Lots of them on Ebay, and pretty cheap to boot!!
                Just cut open the soft pouch, and have at it!!
                  Gary, Great thinking there, yes it would also work.
                  just got the sub trimmed and will now attach the foam and weight and re test. Post pictures in a while.
                  • goshawk823
                    • Oct 2010
                    • 262
                    #69
                    very interested to see if you run into the same issues that David did...
                      Me too!
                      Fresh out of the tub, initial trim done.
Name:	Bronco Type 23_201.jpg
                      It worked out nice that while surfaced, I got the aft end to set low unless I over filled the ballast tank, but level while submerged.
Name:	Bronco Type 23_202.jpg
ID:	89334Click image for larger version
Name:	Bronco Type 23_203.jpg
Name:	Bronco Type 23_204.jpg
                      The total weight was 12.5 ounces. Aft weight was 54.5g
Name:	Bronco Type 23_205.jpg
                      Mid section has two weights, the aft most is 76g and the foreword most is 118.5g
Name:	Bronco Type 23_206.jpg
                      The bow is 106g
Name:	Bronco Type 23_207.jpg
                        David came up with the solution to the pump. It has a 11 Ohm resistor to limit the voltage going to the pump. Since I am currently running at 7.4 volt instead of 11.1 volt as designed, he recommended I cut it out. Since I might use 11.1v in the future, I went ahead and strapped the resistor out. When I do use 11.1v I will remove the jumper.
Name:	Bronco Type 23_208.jpg
                        Tomorrow will be a pool run!
                        Tested the pump works perfectly. Thank you David.
                          Can't wait to see if you'll have better luck than David taming this beast.
                            Me too!.................
                              Here is the pool report. She ran great. I did have issues with chlorine, in fact in the first segment you will see the sub pop up from losing radio contact.
                              Happy New Year!
                                You tease! I can't get the video to play. Whaaaaah!
