Linear output on radial servo
  • Ed Kirk
    • Dec 2025
    • 91
    • TuptubBuilder
      • 152
      Wouldn't it cause bending the control rod?
      As configured, yes. If you choose this method, you should use two bearing spred as far apart as possible to support the push rod.
      • TuptubBuilder
        • 152
ID:	194840 Click image for larger version
        Has anyone else tried bevel gears? They are 95% mechanically efficient.
        • Ed Kirk
          • Dec 2025
          • 91
          OK, I finally managed a video. Too simple to believe but it works.
            • 13924
            Originally posted by Ed Kirk
            https://youtu.be/7Hz9KSJS2-o
            Excellent. Thanks for the video. Proved your point. Has utility.
              • Oct 2017
              • 1034
              My solution:
ID:	194847 Click image for larger version
              • Ed Kirk
                • Dec 2025
                • 91
                Nice - clean.
                  • 3657
                  Interesting endcap you got there TuptubBuilder. Can you share some more info? Thanks
                    • 3727
                    This is an excellent expose on linear servo solutions. Need to book mark this.
                    • TuptubBuilder
                      • 152
                      It's a modified RC-Shipyards WTC. I would elaborate more but I'm dealing with a family emergency.
Name:	Screenshot 2026-04-25 055854.png
