Linear output on radial servo
  • Ed Kirk
    • Dec 2025
    • 91
    • TuptubBuilder
      • 153
      Wouldn't it cause bending the control rod?
      As configured, yes. If you choose this method, you should use two bearing spred as far apart as possible to support the push rod.
      • TuptubBuilder
        • 153
ID:	194840 Click image for larger version
        Has anyone else tried bevel gears? They are 95% mechanically efficient.
        • Ed Kirk
          • Dec 2025
          • 91
          OK, I finally managed a video. Too simple to believe but it works.
            • 13972
            Originally posted by Ed Kirk
            https://youtu.be/7Hz9KSJS2-o
            Excellent. Thanks for the video. Proved your point. Has utility.
              • Oct 2017
              • 1097
              My solution:
ID:	194847 Click image for larger version
              • Ed Kirk
                • Dec 2025
                • 91
                Nice - clean.
                  Interesting endcap you got there TuptubBuilder. Can you share some more info? Thanks
                    • 3746
                    This is an excellent expose on linear servo solutions. Need to book mark this.
                    • TuptubBuilder
                      • 153
                      It's a modified RC-Shipyards WTC. I would elaborate more but I'm dealing with a family emergency.
Name:	Screenshot 2026-04-25 055854.png
