Linear output on radial servo
  • Ed Kirk
    • Dec 2025
    • 84
    Strange idea, why rotate linkage when the servo can be rotated. The idea came to me the other night to hinge the servo to rotate around the linkage. I don't know where the idea came from, I am a fan of antique steam and diesel engines and maybe seen the concept there.
    I may have had the idea before but didn't have the means to make it work.
ID:	194758 Click image for larger version
ID:	194759 Click image for larger version
ID:	194760 Click image for larger version
    • 3560
    Video of them working? I feel that the whole servo will just swing if the controls shafts encounter some resistance.
      • Oct 2017
      • 1007
      Right. Actio=re-actio. You need a soldid servo mount and an excenter lever between horn and rod
      • Ed Kirk
        • Dec 2025
        • 84
        I'm not set up to do video, I tried.
        Does work, no lost motion, very solid servo mount, probably won't work with long rod like when using a bellows. Just keep pivot point in line with rod and the hinge as long as possible. Any way it's free to try.
          • 1998
          I'm not understanding the swiveling servo idea. They'll just swivel back and forth, leaving the shaft in place, will they not.
          I think this is more what you should investigate: https://www.rc-submarine.com/product...a-s3004-servos
          Really simple, cheap, and easy to implement.
            • 3560
            Click image for larger version  Name:	image.png Views:	0 Size:	35.7 KB ID:	194811
            And the sliding rack and pinion.
              • 1600
              Linear is great. Wish the mini servo’s had them when I was building.
                • 3560
                Can't remember who made this articulated connecting rod Click image for larger version
Name:	Screenshot_20260423_204743_Video Player.jpg
ID:	194815 Click image for larger version
Name:	Screenshot_20260423_204725_Video Player.jpg
ID:	194816 Click image for larger version
Name:	Screenshot_20260423_204706_Video Player.jpg
                  • 13744
                  Linkage Alternatives. Radial-to-linear.
                  • TuptubBuilder
                    • 150
                    I modeled the 3 bar link in Fusion. 3barLink.mp4
                      • 763
                      The best most elegant solution was these on my Will Oudmeyer WTC. Sadly, these linear servos are no longer available. The designer died or stopped producing decades ago. It was a disk with a thin wire wrapped around the disk's circumference. But maybe someone could make new ones using same principle. The also perform in less space too. Orange color also made then easy to see operating.​​​
                        • 1998
                        Those are my cylinder endcaps... ;)
                          • 3560
                          How about a Scotch yoke?
                            • 13744
                              • 3560
                              Wouldn't it cause bending the control rod?
