Building my own high quality seals...
  • Fishb0y
    • Jul 2023
    • 167
    After reading the chapter in Bob's book and watching his video on building seals for the WTCs, is there a good source for the cup seals and oillite bearings? If you happen to have part numbers to share, that would be great too!
    • 13982
    .125" shaft cup seals, Precision Associates, Inc. 530166 01 022 A31533 01
    .187" shaft cup seals, Precision Associates, Inc. 530166 01 001 A31426 01
    Oilite bearings available from McMaster-Carr.
    • Fishb0y
      • Jul 2023
      • 167
      Excellent, Thank you!
        • 13982
        Fish-boy. A character from the Invader Zim cartoon series (my go-to DVD when working in the shop).
        • Fishb0y
          • Jul 2023
          • 167
          I used to run the aquatics programs for one the Boston YMCAs when I was much younger. My boss could never remember names, so he called me "that fish-boy" for the first month I worked there.
          • wlambing
            • Nov 2020
            • 398
            Beware of assistants named Grrrr!! I miss that cartoon series!
            • QuarterMaster
              • Sep 2015
              • 1244
              You can do all that, or keep it simple stupid.
              5 minute assembly, Rulon bearings, Pushrod can can angle off center.
              I NEVER have moisture in my boats.
              A simple 1/8" pushrod seal
              FWIW, yes you can put Oilite in the wet, but Rulon (Also McMaster Carr) are designed to BE in the wet. NEVER need re-oiling. More forgiving in angular and concentric misalignment over time. Berfect for shaft component not only for shaft alignment, but thrust bearings.
              v/r "Sub" Ed
              • Fishb0y
                • Jul 2023
                • 167
                I’ll need to check those out too, thanks,
                  Suppliers and part numbers were posted to the video that I put on my channel talking about how to build the seals.
                  • Fishb0y
                    • Jul 2023
                    • 167
                    Next time I'll actually watch the video instead of letting it play in the background while I work...
                    • Fishb0y
                      • Jul 2023
                      • 167
                      After Dive Tribe, I finally got off my butt and ordered some U-cup seals (1/8" ID x 1/4" OD) — the same ones from Bob’s video. I had to place a minimum order of 88 pieces, so I’ll have plenty of extras if anyone’s interested. They should arrive in about a month.
                        • 13982
                        Click image for larger version  Name:	image.png Views:	196 Size:	33.7 KB ID:	173319
                        • Fishb0y
                          • Jul 2023
                          • 167
                          I'm really glad you posted these! Did you find any benefit for adding compression on the cup seals?
                            Compression fitting is merely a holder.
                            Adding compression could deform the cup seal causing it to grip the shaft and destroy the delicate sealing lip.
                              • 13982
                              That's an 'X' section O-ring, not a cup seal. Rommel's above explanation is right on point.
