Like a hot knife through butter
    • 2774
    Wonder if one could use one of these in cutting the Bronco Type XXIII.
    Bob showed something similar in one of his recent YT videos.
    • 1168
    Might be OK for a short cut, but a long cut like the XXIII? I’d say no.
    • DrSchmidt
      • Apr 2014
      • 964
      My approach in cutting the Bronco would be:
      Put the hull on the keel ans secure it in place (e.g. with pieces of wood that are hot-glued to the base plate. Then you make two identical templates of the cut out of wood and position them correctly left and right of the hull. Then use a cutting wire (0,25 mm) and make the cut using the templates as guides.
        • 2774
        Nice idea about the box or trough that hold the hull snugly with the top of the two side walls at the level of the hull cut.
        • wlambing
          • Nov 2020
          • 295
          Carefully using a razor saw, just under a horizontal molded weld line can provide very good results. Tedious, yes, but quite satisfactory end result. I also used this method on my 1:72 Gato. A tiny bit of sanding and CA build up on any kerf booger and you're golden!
          • SubSteve
            • Apr 2022
            • 66
            I hear Dave Merriman uses his laser vision to cut hulls...or a Dremel wheel, I forget...
            • CC Clarke
              • Aug 2020
              • 240
              I have Pfrozen's Beam Cure which is excellent - especially when UV-curing putty and resin applied to seams. The light will easily penetrate a 3mm thick hull.
              I passed on their next product, the Sonic Sabre which is designed to cut through small resin supports, not plastic. Nice for miniatures, but I have other hand tools that do the same job for a lot less.
              YMMV.
                • 1168
                You better watch that. David doesn’t like his secret superpowers being talked about.
                  • Oct 2017
                  • 724
                  Id mark the cutting line with a pen and a ruler and use a japan saw/razor saw. Heat/ that vibro-blade etc ruins the styrene hull in my experience. A sharp hobby knife along a steel ruler might work, too.
                  • Bob Gato
                    • 831
                    If I had to make that cut I would use one of these... They're made by various manufacturers I have a Dremel- I use it for everything... It does plunge cuts and will follow a straight line almost all by itself... Fiberglass, plastic and wood no problem...
                      • 1790
                      Well, Logan and I just checked, and our ultrasonic knife sliced through the styrene hull of a skipjack kit like butter, leaving the tiniest kerf and a perfectly straight line. I video'd the process and it will be included in my next update video posting this weekend, but until then, take my word for it, this is DEFINITELY the way to cut a hull....
                      • CC Clarke
                        • Aug 2020
                        • 240
                        Can't wait to see it in action!
                        • Fishb0y
                          • Jul 2023
                          • 76
                          How do you think this would work cutting a fiberglass hull?
                            • 1168
                            Bob, can you post a picture of the product and where you got it? I hope it’s not the one on Amazon for 1200 bucks.
                              • 1168
                              Come on Bob, give
