Professional grade work there, Rob! Very nice!
Hms holland 1 build
Today I have been working on the sealing up the joints on the interior with resin and fiberglass. I also fabricate the WTC hold down straps!
I used Velcro and fastened them using small screws through the bottom of the hull to secure them in place.
Today I have started to do some work on the hull!
I have some gaps at the stern area that need a little fill work.
I do use 2 part epoxy type fillers sometimes, but on the stern I chose to use strips of PLA for the gap filler. I will then sand it all down flush.
On this portion of the hull I chose to use the 2 part filler to fill in the gap.
What would I do without your keen eye! You certainly have a point.
The above photo (PDF files that were part of print files) shows the end cap where the prop shaft protrudes. (PALIER AR) I used the end cap as my exit point and shaft support but with no gap around the shaft.
I do understand what you are saying and have given it some thought through the night. I may have come up with a possible solution!?
I have incorporated 3 - 5/16" holes in the below water line area of the stern. There are several large holes in the bottom of the stern so with my added holes this should give some water circulation. I really do not want to try and take the existing stern off and replace with an entirely new design!
I do thank you for your keen eye and for taking the time to keep me in check!! :-))
ESSAI 2 HOLLAND S1 - YouTube
"Firemen can stand the heat"Last edited by rwtdiver; 09-14-2022, 03:31 PM.Leave a comment:
Interested to see how that small propeller moves water specially being obscured by the big stern.
Maybe print a new stern cone that tapers down to the propellers hub.Last edited by redboat219; 09-13-2022, 11:20 PM.Leave a comment:
Today I can finally say that the stern section of the Holland is complete!! :-))
These two top photos show the rudder (right) and the dive plains (left) linkage installation and final hook up! You can also see the main drive shaft and the prop system is in and complete.
This photo shows the total completed stern section. At full throw on the rudder and dive plain sticks I am getting between 30 to 40 degrees deflection on both directions! This has been somewhat of a challenge to get together. The entire stern section on this boat can be completely dismantled because of the use of stainless steel fasteners which would allow for any type repairs if required!
Next will be to move on to the hull completion and the mounting system for the WTC.
Tonight, I got the main drive shaft connected up to the prop, and the servos set up for the rudder and the dive plains!
Tomorrow I will cut the linkage rods to add the magnetic couplers, and then mount the horns to the control surfaces.
Eiven though I can't be there I am excited, and I sure will be thinking about you guys and the great time you will all be having! :-)) Have fun and stay safe!
Special Note: I want to pay tribute to all the first responders that paid the ultimate price for their heroism, and those that were injured on 9/11/2001...
"Firemen can stand the heat"Last edited by rwtdiver; 09-11-2022, 03:53 PM.Leave a comment:
Thank you Steve!
My cylinders sure do not hold a candle to those you fabricate for large scale submarine, not only in size, but complexity! But having only a swimming pool to operate in allows me a much simpler type of cylinder to operate with. The cylinders you engineer and fabricate for your large subs are a sight to behold! I do envy you and your talents!!
I bet you and all those going to SubFest are now counting the hours! :-))
This afternoon I was able to install the WTC into the hull so that I could line up the main drive shaft, and the rudder and dive plain control linkages!
As you can see in the above two photos I was able to get a straight shot on the main dive shaft, as well as the rudder and dive plain linkages! I am very pleased to say the least!!! :-)))
"Firemen can stand the heat"👍 1Leave a comment:
Very clean cylinder layout Rob. You are getting closer to being done with another one.Leave a comment:
I finished up the WTC for the Holland last night!
The above photo shows the change I made as to the Receiver (which I purchased from Nautilus Drydocks) antenna install! I have tested this system out to 40 feet and in the water, and it worked great! I do not run my boats anywhere except my swimming pool. The furthest away I would ever be is 25 feet from the sub. I weighted the cylinder down to 1 foot below the surface stood off 15 feet and it performed great!
I did install a remote on/off system that I purchased from Nautilus Drydocks and it works great on a 3 cell (11.1 volt) battery. I also added a voltage indicator to the power side!
Now that the WTC is complete, I will move onto finishing up the stern section of the hull and hooking up the rudder and dive plain linkages!
"Firemen can stand the heat"Last edited by rwtdiver; 09-10-2022, 02:57 PM.Leave a comment:
