In search of, micro LED's
  • Ken_NJ
    • Sep 2014
    • 774
    I'm looking for micro size LED's, say about 1mm diameter, that light 360 degrees. To be used as the flashing submarine beacon light, which will flash for 3 seconds, then off for 3 seconds. I'll be using it with a Bluno Beetle circuit board. Frank Salerno has some on his Seaview but they don't seem to be available. He mentioned check RC car or truck sites. I looked at Litz LED's but most I saw are 120 degree, not the 360 I want.
    See this post about it. Ed posted the code for the beetle.
    Had a free second today so I made a simple circuit and wrote the code for it. Points if you know the language and know what it says. It’s a little fast so pay attention. I sure you ol salty dogs will recognize it right away. https://youtu.be/wK1wCBYDFUE
    • 3547
    Ken,
    Check out - https://evandesigns.com/products/chip-nano-pico-leds
    Tom
    • Ken_NJ
      • Sep 2014
      • 774
      Those are surface mount LED's Tom. Would only light in one direction.
        • 3547
        Agreed, so mount the led facing up, put a clear styrene rod on top of that, drill a cone on top of styrene, fill with silver paint.
        • Monahan Steam Models
          • 755
          Ken,
          Have you taken a look at Digikey to see what they have? I wonder if fiber optic strands could work? Sometimes those cheap miniature Christmas trees use them to imitate miniature bulbs but the strands may not produce the illumination your looking for around the fiber strands circumference.
          Nick
          • CC Clarke
            • Aug 2020
            • 240
            A multitude of choices pop up if you Google 1mm LEDs. Mouser and Digi-Key are common vendors for just about any electronic component. A hemispheric LED would be a more realistic choice than a square SMD, and easier to work with.
            CCC
            • Bob Gato
              • 831
              eBay... Pre-wired surface mount LEDs on hair thin litz wire ..here's an example ...https://www.ebay.com/itm/31320385423...RoCM8IQAvD_BwE
              • Bob Gato
                • 831
                These are $0.69 each... But if you search more you can get them for much less... Sometimes I buy them just for the wire and I throw the LED away LOL...
                If you want 360 degree light-drill out a Lucite rod and insert the LED facing up-then fill the tube with crystal clear glue (like gorilla Clear)
                  • 803
                  For the one I put on my Columbia I potted a micro LED straight up in clear resin at the top of a 1/16" dia. aluminum tube. Worked well. Ebay is loaded with the LED's
                  • Ken_NJ
                    • Sep 2014
                    • 774
                    Many things to check into, thanks guys. Don't think I'll find a hemispherical LED in the size that is ready to go. I did check DigiKey. May have to use a micro litz LED/SMD like some said and pot it like Steve & Bob mentioned.
                    • Bob Gato
                      • 831
                      This example was not for an underwater use but it could be and its food for thought for al who read it (1mm Litz wired SMD)...BG
                      https://www.rcgroups.com/forums/show...&postcount=107
                        • 2759
                          • 2121
                          Buy Warm White LED Lights - 1mm online at Green Stuff World⭐. Scale models, and board games
                          • Ken_NJ
                            • Sep 2014
                            • 774
                            I was not able to find 360 degree LED's so i went with 0402 LED's from Amazon. With a caliper they measure around 0.060, so they are very very small. They only illuminate 120 degrees like a few of you mentioned. After testing the LED's, I put some CA on the backside to seal the connections. I then carefully slid two of them back to back into a 1/16" brass tube and glued them together. I then used epoxy and dipped the LED's in upside down and let the epoxy dry. I did this three times to build up the epoxy. You can see how crystal clear the epoxy is. I then wet sanded the side down with 400 and 2000 grit paper. I filed the top flat and wet sanded with 2000 grit. The sanding gave a a frosted effect. Each LED will get a CL2N3 driver. The input voltage to these can be from 5 to 90 volts and the output will always be 20ma no matter what the input voltage is. With resistors, if the voltage drops, the current drops and the LED will get dimmer. So as long as the LED spec is 20ma, the CL2N3 will always supply 20ma. You can see what I made in comparison to the faux beacon that came with the Skipjack kit. With two of them back to back, I get the effect I was looking for. Now I just need to install it and get the Bluno Beetle setup.
                            Amazon LED's
                            CL2N3 LED driver
                            Bluno Beetle
                            DFRobot Beetle Ble is an Arduino Uno based board with bluetooth 4.0 (BLE). It is probably the smallest Arduino BLE board on the market.
                              • 755
                              Very cool. Nice work Ken!
