To solve your problem, I recommend using the small smart light bulbs that you can find in online/offline stores. The good part about these bulbs is that you can set them in the right way to make them work as a whole system, so you don't need to make the switch per bulb. I find this is really important in your situation since you mentioned that you are working on an RC car model. If you need help setting the bulbs in the right way, reach me via private messages, I will be glad to help you.
