Japanese Sen Toku I-401 Submarine Build
    • 3523
    #91
    Rob, can you post a close up photo of the plane and hanger bay?
    • Sam Victory
      • Sep 2021
      • 391
      #92
      I have very detailed information on the I-400 class submarines, many detailed aspects of their construction. It was very difficult to completely figure out the structure of this submarine (at least in appearance), and the US navy destroyed all information on the I-400 class submarines to the point that later information was based on the recollections of veterans who served on Japanese I-400 submarines after the war. So any drawings of the I-400 submarine now are not original sources, but only the memories of veterans.
      V
Name:	Seiran plan (from AviO No.2).gif
ID:	156071Click image for larger version
ID:	156072Click image for larger version
Name:	Stored Seiran.jpg
ID:	156073Click image for larger version
ID:	156074Click image for larger version
ID:	156075Click image for larger version
ID:	156076Click image for larger version
ID:	156077Click image for larger version
ID:	156078Click image for larger version
ID:	156079Click image for larger version
        • 1937
        #93
        My version of the i-401 is about as complete as it is going to be. I have a general representation of what the i-401 looked like, which was all I was looking for anyway. I am not, nor am I going to be a so called rivet counter. The aircraft that I have depicted is not the Seiran Aichi M6A1, it is a 3D printed basic Japanese Zero look-a-like. The hatch on the aircraft storage area does not open, again I just chose not to go into that kind of detail work.
        I will be doing a little more overall splash on paint work to achieve the look that I am after, and then that will be it!
        I want to really give Sam a REALLY BIG THANK YOU for all the photos and description work that you have put on my build blog. I thank all of you that have contributed as well!
          • 3523
          #94
          Not counting rivets either, just want to see what you did.
            • 1937
            #95
            Sorry Ramel!
            Did not mean to forget the photo you wanted to see.
Name:	i-401 aircraft.jpg
ID:	156084Click image for larger version
Name:	i-401 aircraft 2.jpg
            I still have some fill in and sanding to do on the aircraft, and then I will do it up in the original colors of the aircraft.
            • gantu
              • 392
              #96
              Regards Gantu
                • 1937
                #97
                Originally posted by gantu
                gantu,
                Extremely nicely modeled i-400! Must have taken you many hours to achieve such a nice model! I assume it was a kit?! And not manufactured from 3D printing!? Thanks for sharing your work!
                  • 3523
                  #98
                  Nice! Thanks Rob.
                  • gantu
                    • 392
                    #99
                    Hello rob this not mine model i found those pictures years ago by research about the i400 class.
                    Regards Gantu
                    • gantu
                      • 392
                      #100
                      Regards Gantu
                      • gantu
                        • 392
                        #101
                        If I understood it correctly, the original plans of the i400 class were destroyed shortly before the arrival of the US Navy. Today's plans come from a reconstruction iuch can also deceive me is long where I had read it on the Internet. I have uploaded several pictures one shows a cad drawing there you can see the differences.
                        Regards Gantu
                        • gantu
                          • 392
                          #102
                          Regards Gantu
                            • 1937
                            #103
                            Gantu,
                            Thank you again for posted up all this great information. I see there was a difference between the i-400 and the i-401 boat. Very interesting information.
                            Building the i-401 from scratch has been a real learning process for me, mostly because of the history behind the building of the actual boat. Knowing that this boat was really a last-ditch effort by the Japanese to
                            possibly change the outcome of the war. It's too bad the human race can't find a way to put all this inspiration and effort into bringing about piece in the world, in place of building all these killing machines! Hopeful thinking on my part I guess!!!
                            I hope Steve (RCJetdude) can use this information, because I think he and his son are going to build a 1:48 scale of the i-400!
                              • 821
                              #104
                              I hope Steve (RCJetdude) can use this information, because I think he and his is going to build a 1:48 scale of the i-400!
                              It will be very helpful when the time comes. Thank you for starting this thread Rob. Your build has brought together your experience and talent with all this great input.
                                • 1937
                                #105
                                Thank you, Steve,
                                If your build comes about, it will certainly be a build to follow for sure!
