Japanese Sen Toku I-401 Submarine Build
  • yiannis
    Dear fellow I-40x friends,
    I have just joined the RC-sub community and was always hoping that after my retirement from the Naval Research Lab (that just happened last month), I would be able to build an I-400/401 at 1/72 scale. To my great surprise, I was elated to find your postings here and the incredible progress from Sinksalot !!! Since almost 3 years have passed since the last posting here, I am wondering if there is a place I can go to get the most recent and corrected files for printing the I-40x, along with any other additional info for making a full RC version of it with WTC inside and everything else. I would appreciate tremendously any response.
    Any updates?
  • Sinksalot
    Update on I-400, more top hull parts done. I have also started printed in 360mm long sections. Please note no gluing or sanding has been done yet. I am just mocking it up to see how it will look.
  • Sam Victory
    The currently 3D printable model of the I-400 submarine is here: I-400-class submarien | 3D Warehouse (sketchup.com)
    the original author modeled it with Sketch Up software.
    Then someone changed the original file into an RC version, which can be seen on the "Thingiverse" website.
    Comments for I-401 Sen Toku 1:72 RC Submarine by HatsuneR - Thingiverse
    One thing to note, however, is that the original 3D model has dimensional errors, both in width and length, which may be related to the inaccuracy of the modeling drawings, as I have studied every aspect of the submarine very carefully. You can see that some people on the Thingiverse site have questioned the dimensions of the model itself, but that's okay, it's still a great model!
    Other RC submarine 3D models:RC submarine HMS Gotland 1/48 by Ewolve - Thingiverse
    V
  • Sinksalot
    Are you using a Resin printer on these? They look fantastic! Good job sir!
    Yes, I used a Saturn resin printer to print those guns The guns even move left and right and the gun barrels move up and down. I can tell you I went thru 15 different updates to the design to get it right. But if i can do it, anyone can do it.
    Originally posted by Sinksalot
    Yea, the more guns I make, the better I get at it. I designed and printed the 3.7cm and 2cm AA guns for my 1/45 scale Engel Type IX.
    Here is a picture of those guns. I hope the new gun looks just as good after a few tries with the design.
  • Sinksalot
    First prototype Japanese triple AA gun for the I-400. I am slowing thickening parts as at 1/72 its small. First try at printing with my Saturn resin printer failed do to thin parts. Will try again after I update file more.
    I did manage to get a pretty good representation on those deck guns, but I had to scratch build them!
  • Sinksalot
  • Sinksalot
    Steve, no it all ASA. I did print a top part in resin, however when I design the top parts I had to make them a little thick some of the places. After I finished the resin print on one of the top parts, i was amazed at how heavy the part was. So I went back to ASA for the whole hull of the sub.
    So far I am happy as to how the hull is shaping up for this I-400. I just finished a top part.
    David, is that all resin printed?
    Sinkalot,
    Your l-400 is really looking good! I think the way you have the upper and lower hull mating up with inside flanges will make for a nice fit. You might consider using pins to help line up the two hull sections as well!
  • Sinksalot
  • Sam Victory
ID:	156394Click image for larger version
ID:	156395Click image for larger version
ID:	156396Click image for larger version
ID:	156397Click image for larger version
ID:	156398Click image for larger version
ID:	156399Click image for larger version
ID:	156400Click image for larger version
ID:	156401Click image for larger version
  • Sam Victory
    The third picture has a lot of content, the upper left corner is about the periscope * 2, electric probe * 1 lift, you can see three mini cylinders (can be homemade) ~ can lift independently. Separate control the periscope * 2 and electric probe * 1 . The three cylinders are independently connected to three small solenoid water valves, the medium passed into the cylinder is water, so only a peristaltic pump is required. The top right corner of the picture is about the command tower of the two radar rotating structure, the structure is very simple. The thing you see like a rotating pistol drum is actually a magnetically coupled connector (the top and bottom connectors are not touching), controlled by a gear motor. I use the magnetic coupling connector to control the radar*2 rotation is to consider in the upper and lower hull separation disassembly will be much easier, this structure is also very simple. There is also a geared motor, also using the magnetically coupled connector, for controlling the AA-guns*4 left and right oscillation (need motor PWM control module). The lower part of the picture shows the aircraft ejection device, which is fixed to the deck by magnets and can be disassembled to replace the original deck structure. The solenoid valve ejects a small amount of gas in an instant (I forgot to specify that the gas source for the 10 solenoid valves on the bow is from a U-shaped copper storage tank outside the WTC, and there is a throttle valve on the resin supply line for the 10 solenoid valves, which regulates the gas pressure to the right level to provide the 10 solenoid valves, and I have considered that the gas pressure required for torpedoes, aircraft ejection, and emergency surfacing is roughly similar).
    Describing these images would require a lot of text, so this would take a lot of my time, so I think these images are just for show. I probably won't go on about the principles of my design, or when I have the time. My task is done.
