Russian Alfa Class
    The Russian Alfa is finished! I used one of my custom built cylinders for the propulsion system!
Name:	Alfa Finished.jpg
ID:	154848Click image for larger version
    Hope you all enjoyed the build blog, and I thank you all for your input!
      I am going to re-open my Russian Alfa boat design and re-build again! As per the last results with my Piston Tank design that would not fit into the 1:72 scale hull design, I am going to try utilizing a "Vented (low pressure) Ballast System"
      Click image for larger version  Name:	Ballast System.jpg Views:	0 Size:	52.5 KB ID:	156779
      I have laid up a drawing based somewhat on the design in "Bob Martins" new book! This system will be going into a new 1:72 Scale Alfa 3D printed boat. This will be my own scratch built WTC and ballast system design.
      The design is somewhat basic at this point. I have listed above 4 possible pumps that may or may not work for this design. With this in mind, I would really like some input as to my principal design and function!
      Also in looking at the pumps I have, which one might work the best for this design!
      Thank you all for your help!
      PS: I am done with building "Target Boats" sort of boring for me! Another lesson learned again!!!
        Check out Nate He's Blueback.
          • 13982
          #109
          Gonna have to be a gear-pump if you want it to move water both ways.
          Or a one-way pump that leaks during the 'flood' cycle, which means a centrifugal type pump. You'll have to provide a servo/solenoid actuated vent valve, and a 'pinch-valve' to keep water from back-flooding the tank through the pump when on the surface.
          Welcome back to the Dark Side, Rob.
            Thanks for checking in David.
            If I understand you correctly the system in the photo below using 2 micro switches and servo connected to the pump to pump water in and then reverse the pump to pump water out.!?
Name:	Drive system 2.jpg
            This was the system I used on the piston ballast system! So instead of a piston, I would be using a pump to move water in or out!?
              • 13982
              #111
              If what you have there is a gear type pump (which is reversable), and the switches are for polarity swapping, then that's all you need (and the fixed vent, of course).
                Thank you for getting back to me David. I really appreciate all your expertise and input!!
ID:	156807Click image for larger version
Name:	Geared Pump 2.jpg
Name:	Geared Pump 3.jpg
                Would this pump be considered a geared pump? It came out of a Krick U-Boat kit.
                Thanks again for your time David!
                  • 13982
                  #113
                  Yup.
                    Yup.
                    Thanks David!
                    I am going to do another updated drawing as to how all the components will come together. I would appreciate your comments on it and if you think my design might work.
                      • 13982
                      #115
                      Your initial sketch had it right: a reversable pump plumbed directly to the bottom of the ballast tank, and a vent up high in the sail. That's it. Finishe, move on, job done, Miller Time.
                        Thank you David,
                        I do have a couple of drawings to sort of confirm what you have said! (Thank you)
Name:	Geared Pump System.jpg
Name:	Geared Pump System 2.jpg
                        OK! Thank you David! I do appreciate ALL your help and expertise with my latest project.
                          • 13982
                          #117
                          Your gear pump will leake-by just a bit, but nothing the occasional, 'empty' command won't fix.
                              Ramel! Thank you for the information! I have a much SIMPLER method for bringing my sunken Submarines to the surface!!
Name:	Sub catcher 4.jpg
ID:	156851Click image for larger version
Name:	Sub catcher 2.jpg
Name:	Sub Catcher 1.jpg
ID:	156853Click image for larger version
Name:	Sub catcher 3.jpg
                              Nothing complicated here! Sure fire, and works every time!!
                                I am making some headway on the Alfa hull build. I am using white Dremel PLA, and 100% infill.
Name:	New Alfa Build 1.jpg
