Russian Alfa Class
    • 1821
    The Russian Alfa is finished! I used one of my custom built cylinders for the propulsion system!
Name:	Alfa Finished.jpg
ID:	154848Click image for larger version
    Hope you all enjoyed the build blog, and I thank you all for your input!
      • 1821
      I am going to re-open my Russian Alfa boat design and re-build again! As per the last results with my Piston Tank design that would not fit into the 1:72 scale hull design, I am going to try utilizing a "Vented (low pressure) Ballast System"
      Click image for larger version  Name:	Ballast System.jpg Views:	0 Size:	52.5 KB ID:	156779
      I have laid up a drawing based somewhat on the design in "Bob Martins" new book! This system will be going into a new 1:72 Scale Alfa 3D printed boat. This will be my own scratch built WTC and ballast system design.
      The design is somewhat basic at this point. I have listed above 4 possible pumps that may or may not work for this design. With this in mind, I would really like some input as to my principal design and function!
      Also in looking at the pumps I have, which one might work the best for this design!
      Thank you all for your help!
      PS: I am done with building "Target Boats" sort of boring for me! Another lesson learned again!!!
        • 2764
        Check out Nate He's Blueback.
          • 12363
          Gonna have to be a gear-pump if you want it to move water both ways.
          Or a one-way pump that leaks during the 'flood' cycle, which means a centrifugal type pump. You'll have to provide a servo/solenoid actuated vent valve, and a 'pinch-valve' to keep water from back-flooding the tank through the pump when on the surface.
          Welcome back to the Dark Side, Rob.
            • 1821
            Thanks for checking in David.
            If I understand you correctly the system in the photo below using 2 micro switches and servo connected to the pump to pump water in and then reverse the pump to pump water out.!?
Name:	Drive system 2.jpg
            This was the system I used on the piston ballast system! So instead of a piston, I would be using a pump to move water in or out!?
              • 12363
              If what you have there is a gear type pump (which is reversable), and the switches are for polarity swapping, then that's all you need (and the fixed vent, of course).
                • 1821
                Thank you for getting back to me David. I really appreciate all your expertise and input!!
ID:	156807Click image for larger version
Name:	Geared Pump 2.jpg
Name:	Geared Pump 3.jpg
                Would this pump be considered a geared pump? It came out of a Krick U-Boat kit.
                Thanks again for your time David!
                  • 12363
                  Yup.
                    • 1821
                    Yup.
                    Thanks David!
                    I am going to do another updated drawing as to how all the components will come together. I would appreciate your comments on it and if you think my design might work.
                      • 12363
                      Your initial sketch had it right: a reversable pump plumbed directly to the bottom of the ballast tank, and a vent up high in the sail. That's it. Finishe, move on, job done, Miller Time.
                        • 1821
                        Thank you David,
                        I do have a couple of drawings to sort of confirm what you have said! (Thank you)
Name:	Geared Pump System.jpg
Name:	Geared Pump System 2.jpg
                        OK! Thank you David! I do appreciate ALL your help and expertise with my latest project.
                          • 12363
                          Your gear pump will leake-by just a bit, but nothing the occasional, 'empty' command won't fix.
                            • 2764
                              • 1821
                              Ramel! Thank you for the information! I have a much SIMPLER method for bringing my sunken Submarines to the surface!!
Name:	Sub catcher 4.jpg
ID:	156851Click image for larger version
Name:	Sub catcher 2.jpg
Name:	Sub Catcher 1.jpg
ID:	156853Click image for larger version
Name:	Sub catcher 3.jpg
                              Nothing complicated here! Sure fire, and works every time!!
                                • 1821
                                I am making some headway on the Alfa hull build. I am using white Dremel PLA, and 100% infill.
Name:	New Alfa Build 1.jpg
