Russian Alfa Class
    I have the bottom sections of the Alfa hull completed!
Name:	Alfa WTC 2.jpg
ID:	156970Click image for larger version
Name:	Alfa WTC 3.jpg
Name:	Alfa WTC 1.jpg
    I also purchased two 24" cylinders (one 3.00" and one 3.50") Not totally sure which one I will use just yet. I have the 3.50" cylinder in the two photos above. Until I get the top hull sections complete, the cylinder selection is up in the air at this point.
  • neitosub
    That is a great advantage of 3D printing programs, you can rescale a boat very easily!
    Nate
    Originally posted by neitosub
    Always loved the Alfa class, 1/72 is a bit too big for my liking but 1/96 scale is perfect.
    NEITOSUB,
    My Alfa build is not a true 1:72. I purchased the files from Nautilus Drydocks (1:96 scale) and modified the size of the files to get as much additional length to my build as possible using my DREMEL 40 3D printer. 170mm is my max height on this machine. I took Bob Martins files and I am building at 125% which is a little smaller than 1:72 scale, not sure what the scale is! I am scratch building my WTC system for my boat, and will need the extra length.
  • neitosub
    Looking good Rob. Following along.
    Thanks Steve,
    I am really looking forward to building this Alfa out to the fullest extent that I can. A WTC with a proper working ballast system, functioning diving plains, rudder, and propulsion system. And when that has been achieved, a properly finished out David M. hull!
    I am making some headway on the Alfa hull build. I am using white Dremel PLA, and 100% infill.
Name:	New Alfa Build 1.jpg
    Ramel! Thank you for the information! I have a much SIMPLER method for bringing my sunken Submarines to the surface!!
Name:	Sub catcher 4.jpg
ID:	156851Click image for larger version
Name:	Sub catcher 2.jpg
Name:	Sub Catcher 1.jpg
ID:	156853Click image for larger version
Name:	Sub catcher 3.jpg
    Nothing complicated here! Sure fire, and works every time!!
    Your gear pump will leake-by just a bit, but nothing the occasional, 'empty' command won't fix.
    Your initial sketch had it right: a reversable pump plumbed directly to the bottom of the ballast tank, and a vent up high in the sail. That's it. Finishe, move on, job done, Miller Time.
    Thank you David,
    I do have a couple of drawings to sort of confirm what you have said! (Thank you)
Name:	Geared Pump System.jpg
Name:	Geared Pump System 2.jpg
    OK! Thank you David! I do appreciate ALL your help and expertise with my latest project.
    Yup.
    Thanks David!
    I am going to do another updated drawing as to how all the components will come together. I would appreciate your comments on it and if you think my design might work.
    Thank you for getting back to me David. I really appreciate all your expertise and input!!
ID:	156807Click image for larger version
Name:	Geared Pump 2.jpg
Name:	Geared Pump 3.jpg
    Would this pump be considered a geared pump? It came out of a Krick U-Boat kit.
    Thanks again for your time David!
    Yup.
    If what you have there is a gear type pump (which is reversable), and the switches are for polarity swapping, then that's all you need (and the fixed vent, of course).
