  • scubaed1911
    • Jul 2019
    • 45
    After 18 months after I ordered the Type-VII, and your work on the 1/48 scale torpedo system thanks!
      • 2753
      Hi Bob,
      Can you expound more about the 2" SD you converted to external twin brushless. Click image for larger version
      • Andre Barbugiani
        • Jun 2016
        • 1
        I'm interested in my 2.5. Which esc you used.
          • 1777
          Hi Bob,
          Nothing crazy in terms of that. I simply removed the brushed motors internally and added the brushless externally. Two motor wiring passes through the bulkhead with bullet connectors. Each motor has its own dedicated ESC (you can't run multiple brushless motors off of one ESC).
          I'm not sure I follow your question, but if you're asking with brushless ESC's I use, then they re BLHELI32 units, available on my website.
