today's work
    • 1651
    #871
    Relating to the pitchdown effect, at mine it only occurs at topspeed, i"ve set the speedcontrol at max 3/4, i suspect it has to do with the hydrodynamic effect of the tower, don"t know if others have the same problem.
    So, the V80 is next on the list, has to cured by now.
      • 13989
      #872
      Yeah, your wonderful little V80 hull is rock-solid by now. It's in the rotation. Only 12 models ahead of it. We'll get there, old friend.
      I had a fundamental control problem I never had time to resolve with the Bronco Type-23. It would pitch down the moment it moved, so speed was not the issue. Now, with time to spare, any like problems with the new Type-23 can be resolved.
        • 1651
        #873
        This sounds more as the levelkeeper or servo flutter, CG you will notice directly, mine is straight under the tower.
          • 13989
          #874
          I hear you. The angle-keeper was observed to do its job: I would hand-hold the model in the water and pitch it up and down, and the stern planes would respond correctly. The boats CG was at the longitudinal center of hull and low, and the ballast tank was centered there as well. Static stability dead in the water was perfect.
          Seemed I had everything set up right, but the damned thing would, once in submerged trim and the throttle advanced, the model would flip me the bird, yell an obsenity at me, then promptly put its tail up in the air and make for the mud.
          Not So Smart After All
          • wlambing
            • Nov 2020
            • 399
            #875
            The OTW Type XXIII would do the same thing! My bud, Tony, had one that did that years ago, but I don't recall how (or if) that got fixed.
              • 13989
              #876
              So... I'm not crazy?!
              • goshawk823
                • Oct 2010
                • 262
                #877
                I never had that happen with my OTW Type XXIII. I debuted the boat at the Subregatta back in the 90s, and never had that issue running it there or anywhere. I used Bob's original on board compressor WTC with it. The only issue I had with that boat was that I made the rear dive plane linkage with too thin brass rod. Full astern would overwhelm the dive plane throw. It needed to be thicker, with a bit more bracing for the control rod as it passed through the rear of the hull. I did run that boat with bow planes, while the rear planes were on a leveler.
                  • 3761
                  #878
                  Oh you do not get off the hook that easily. A working Type XXIII does not release you from being crazy.....look at me :-)
                    Let’s not get drastic.
                    • wlambing
                      • Nov 2020
                      • 399
                      #880
                      After giving it some more thought, the issue may have been due to trapped air in the bow suddenly moving as the boat dived. Once under and at an angle, the bubble either collapsed or shifted aft and dissolved, causing the sudden and abrupt increase in down angle. I will be observant of how my Bronco reacts when she gets sea-trialed again come spring. Previous "tub trials" showed a propensity towards being heavy aft, thus diving stern-first. I have since changed some things around, so all new to me this coming go-around. Good luck with your efforts!!
                        • 13989
                        #881
                        A possibility. My initial reaction to your suggestion was blustering indignation that anyone would DARE question my ability to vent a wet-hull boat. BUTTT.... I've done stupid **** before. No denying that!
                        I'll take your observation into account when I start punching out topside holes. Thanks, Bill. Nothing sounds louder and with more resonance than the words from someone who's been there.
                        (That doesn't get you off the hook, I still owe you terrible consequences for what you did to my poor 1/72 ALFA two seasons ago! You savage!).
                          • 13989
                          #882
                          The interlocking registration tabs -- a set in the upper hull, and a set in the lower hull -- hold the longitudinal edges in alignment and pull the halves together when the tabs of the upper hull engaged the inside of the lower hull; the slight 'pull-down' compression of the upper hull tabs to the over-hanging lower hull interior provides this closure force.
                          Last thing to install was the forward and after radial flanges. Here I'm CA'ing the forward radial flange, using the same .020-inch thick polystyrene sheet I employed for the kerf-strips that run the length of the longitudinal edges of the lower hull.
                          One can never have too many clamps!
                          All model parts were given a ruthless scrubbing with an automotive grade surface prep, rubbed in with a green abrasive pad. Prep-sol is one brand. It's a hydrocarbon solvent that is strong enough to cut away grease, oil, dirt, and the like, but not quite strong enough to melt you or your model. Good stuff, and the last thing you do before body or paint work.
                          The scratching of the models surface produces some 'tooth' that adds a mechanical element to the adhesive 'stick' of glues, fillers, putties, primer and paint.
                          There were slight miss-alignments at the radial edges, forward and aft. These low spots would be filled with Bondo automotive filler.
                          The kit was assembled from four hull sections, The radial union between the forward and after hull sections presented a slight distortion around the girth of the hull -- an unfortunate artifact of kit design. (Oh, well, that's why God gave us Bondo). The dip there had to be Bondo'ed as well. All areas to receive Bondo automotive filler were marked with pencil, the hash-marks you see here.
                          #200 grit sandpaper provided the additional tooth needed to insure solid adhesion between the polyester Bondo and polystyrene plastic of the model.
                          (how many of you idiots will fixate on the thumb, but not the presentation?)
                          To keep Bondo away from places that don't need it, I applied masking.
                          After troweling on the Bondo I immediately ran a blade along the slight gap between hull halves. Failure to do so would result in the Bondo permanently 'gluing' the two hull halves together. Something to be avoided.
                          (Stop looking at that thumb!).
                          Bondo applied, the masking was removed and I got to work with rasp and sandpaper to feather the filled areas to the contour of the surrounding surfaces.
                          Once the Bondo had cured hard ('green stage' actually, it takes at least 30 days to cure properly) I ground away at the excess material with a rasp file, followed by hard and soft sanding block. The sanding started with #200 grit and worked down to #400. Both the filing and sanding were done wet to prevent clogging of the tools.
                          Cured Bondo, by itself is porous and weak. To those areas that would be subject to stress, such as the longitudinal and radial edges, I applied thin formula CA over the Bondo'ed areas. The adhesive soaked into the surface of the Bondo and greatly strengthened the substrate. After lightly sanding the CA'ed surfaces, things were ready for some Nitro-Stan air-dry touch-up putty to fill all tool marks and slight pits and dings not addressed by the Bondo.
                          I find air-dry putty is best applied with a brush. If need be the putty can be cut with a little lacquer thinner to make it more brush-friendly.
                          Bondo for contouring and major fill jobs. Putty is for shallow scratches and the like. Don't confuse the two.
                          Deep imperfections get the Bondo. Shallow imperfections get the Nitro-Stan. If applied thin (it should never be applied to depths greater than .030-inch) the putty will dry in about an hour. Regard air-dry putty as that last step before primer. Bondo for the deep ugly stuff; putty for shallow tool-marks and the like.
                            Good stuff. I’m particularly fond of the XXIII. It’s simplicity at it’s finest. No guns, or other outside parts like the Type VII models to break. Bare bones, but just a touch of U-boat looks.
                              • 13989
                              #884
                              And a hint of what was to come if they had time to get the Type-18 into series production.
                                • 1651
                                #885
                                Okay, i got to ask,what's with the thumb?, did you plaster it with bondo?, smeared it under with niitro-stan?, glued it with superglue?, share the gory details.
                                Manfred
