today's work
    • 14013
    #436
    OK. turns out the ESC was bad. Replaced with a new one and the motor works fine. I now have a severe range problem. I took Andy's advice and got the BEC away from the receiver, but still I get glitching at only 50' with extended transmitter antenna. Pitiful!
    But, Andy put the thought in my head, and I extended the idea of a signal generator in close proximity to the receiver swamping the front-end with too much RF 'noise'. Right now I have Kevin's AD2 angle keeper servo taped to the side of the receiver. Tomorrow I re-locate that away and see if I get a good range.
    The battle continues.
      A leveller shouldn't be giving off any RFI.
      The electrically dirty things in a sub are brushed motors, ESC's and switchmode BEC's. You may want to try earthing out the aluminium tech rack.
        • 14013
        #438
        The electrically dirty things in a sub are brushed motors, ESC's and switchmode BEC's. You may want to try earthing out the aluminum tech rack.
        Good points, Andy. I'll ground the tray to the receiver ground and see how that works.
        Check me on this: I'll run a lead from an unused port of the receiver and attach the black (negative/ground) wire to the tray. Or will you read about some stupid American killing himself in a shop accident?
          That'll probably work, but best practice is to run it to the battery terminal, to avoid grounds at different potentials. Don't think it'll make much difference in this instance though. other things to try, if the receiver is crystal based, try substituting an alternative crystal, also try the same in the TX. Also worth trying a linear BEC in place of the switchmode in case that is the culprit. I use the same model of BEC without issue, but maybe the 75mhz is a bit more sensitive than our 40mhz.
            • 14013
            #440
            Thank you for the quick response and pointer. Battery ground it is, sir. I'll keep you informed. Before that I'll isolate the BEC and range check with a dedicated receiver battery.
              • 1660
              #441
              Take some copper mesh, make a small box, in which you can place the BEC, this will act as a cage of farady, keeping the RF signals inside.
              Maybe also some a ferrit core around the leads coming in and out.
                • 14013
                #442
                Good stuff, Manfred. I'll employ these ideas if the others don't pan out. Thanks.
                electronics moron
                  • 14013
                  #443
                  OK, this request goes out to you common air-breathers who bask in the glory of my earth-shaking presence, a request of assistance:
                  May I ask you kind sirs, does anyone have any Futaba, 75Mhz FM Dual Conversion Crystals for sale? Specifically I need a TX and RX pair; and if at all possible, I would like two of the RX crystals.
                  And I want them now!
                  Thanks.
                  The All Powerful
                    No such thing as a dual conversion TX crystal. The dual conversion only applies to the RX, and that is the only part that requires a special crystal. Can't help you with the receiver crystals though, the 75mhz band is largely exclusive to USA.
                    I take it you've thrown in the towel with the Novak RX, as it looks like a synthesized model.
                      • 14013
                      #445
                      Yeah, I knew that. I pretty much cut-and-pasted what the SKIPJACK customer was looking for.
                      Like Bob's current battle with his big Type-21, this RTR job has taken a long time with many 'interesting' problems to solve.
                      And you're right, the Novak just would not talk to the transmitters the client submitted to me. However, by going with one of my VEX transmitters and the synthesized Corona (love those things!), I did come up with a workable r/c system for the job. Likely I was trying to get the Novak to work a band it was not tuned for.
                      Crystals are becoming an ever increasing source of angst in this game.
                      I imagine in a few years I'll retreat back to static scale model building -- my roots and my first love. R/c aircraft, boats and cars interest me not in the slightest.
                      • Rick Teskey
                        • Jan 2009
                        • 265
                        #446
                        We will just become 72 mhz outlaws! We need new sombra labs recievers !
                          • 14013
                          #447
                          Sadly you are right on point, my snow covered creature friend. Thank god I held onto the airplane gear -- it might come to that some day.
                            Fantastic radio equipment available these days, and much of it uses modular tuners e.g. the Frsky and Jumper ranges are excellent examples, and they can be had for much less than the cost of a basic 2-channel rig back in the day.
                            The snag is that the older lower frequencies are no longer of interest to major manufacturers as there is little market for them beyond lunatics like us.
                            Here's the thing, it's just a basic tuner and receiver that is required, all the clever stuff is done inside the transmitter. The designs for tuners are mature and by and large open source, so they could be reproduced.
                            Course to make that viable, we need a few buyers. So it needs a bit of organisation.
                            In another vein, there is still a lot of good secondhand and NOS radio equipment washing about to largely satisfy demand. I haven't soon too many people complaining about difficulties entering the hobby through lack of available radio equipment.
                            I still maintain the biggest existential threat to the R/C sub hobby is the ageing demographic, and I'm far from convinced organisations and groups representing the hobby have the will or concepts to address this.
                              • 14013
                              #449
                              As usual, Andy, you put the point on it. Bottom line: this 'hobby' dies with us.
                              Twenty-years from now all this gear will be at the mid-level of the local active land-fill.
                                I don't think it'll die out completely, I just don't think it'll be the same, and I think the hobby will probably be a lot smaller and/or participation will be very different.
                                There are lots of factors that influence this, some of which are easier to mitigate than others.
