today's work
    • 13982
    #3631
    Or did you....
    (If only it were photo-shoped)
      Only good use of AI.
        • 2641
        #3633
        Do you still have the tools for the 1.25" cylinders or have they gone to Bob?
          • 13982
          #3634
          What survived the flood is still in the sheds.
            Gonna need a bigger shed
            • Timothy L
              • Sep 2024
              • 249
              #3636
              David;
              “DISASTER!
              Just one final flattened clear-coat away from completion, in seconds I ruined the finish of Jake's 1/72 SKIPJACK class r/c model submarine through shear overconfidence and non-vigilance.
              I rushed the job; took short cuts.
              I was too enamored with past accomplishments to regard normal set-up precautions as prerequisites, not options.
              I over-doped the clear-coat with flattening agent and thinner.
              I set the touch-up gun with too much product flow and shot the work at too close a distance.
              And I did the job late at night, a bit fatigued, and should have addressed this chore early the next morning, fresh and alert.
              I have since wet-sanded away the above waterline portions of the hull and repainted it.
              Back to square-one because I was an arrogant dumb-ass! Lesson re-learned (yet again!!!)”
              __________________________________________
              Tim:
              Actually those unfortunate slips, well described by David, are a HUGE lesson for builders - newbies like me or not. Using such rare foibles as lessons for others is a real credit to David. I particularly value that post because it is a super, super lesson that should be posted on every wall of my newbie shop. Which is exactly what I will do!
                • 13982
                #3637
                David;
                “DISASTER!
                Tim:
                Much appreciated, Tim. I was taught early in life to fess up to mistakes. Not only to cleans my soul, but to inform and assist any community I attach my wagon to. Presentation of a problem, its cause and fix, serves yourself and your community. Good works must be shared, not squandered.
                When you **** up, SAY SO! Then work to put right what went wrong and share the fix with those who might make the same dumb-ass moves you made. Leave the Craft better than your found it!
                  • 13982
                  #3638
                  FIXYPOO!
                    I don’t see anything. The page is blank other than “fixypoo”.
                      • 13982
                      #3640
                        • 13982
                        #3641
                          • 13982
                          #3642
                          • Timothy L
                            • Sep 2024
                            • 249
                            #3643
                            Are these the Woodland Scenics graphics Gothic 45 degree? Thank you.
                              • 13982
                              #3644
                              Yup. Catalog #747
                                • Oct 2017
                                • 1100
                                #3645
                                David, that JB Weld fast setting epoxy in the picture, so it remains hardened and stable just as slow-setting "standard" epoxy?
                                I am not using "5-min" epoxy for it decomposes over time and is not water-stable (UHU Schnellfest).
                                Net to get that JBWeld!
                                Jörg
