today's work
    • 13725
    #3631
    Or did you....
    (If only it were photo-shoped)
      • 3542
      #3632
      Only good use of AI.
        • 2533
        #3633
        Do you still have the tools for the 1.25" cylinders or have they gone to Bob?
          • 13725
          #3634
          What survived the flood is still in the sheds.
            • 3542
            #3635
            Gonna need a bigger shed
            • Timothy L
              • Sep 2024
              • 132
              #3636
              David;
              “DISASTER!
              Just one final flattened clear-coat away from completion, in seconds I ruined the finish of Jake's 1/72 SKIPJACK class r/c model submarine through shear overconfidence and non-vigilance.
              I rushed the job; took short cuts.
              I was too enamored with past accomplishments to regard normal set-up precautions as prerequisites, not options.
              I over-doped the clear-coat with flattening agent and thinner.
              I set the touch-up gun with too much product flow and shot the work at too close a distance.
              And I did the job late at night, a bit fatigued, and should have addressed this chore early the next morning, fresh and alert.
              I have since wet-sanded away the above waterline portions of the hull and repainted it.
              Back to square-one because I was an arrogant dumb-ass! Lesson re-learned (yet again!!!)”
              __________________________________________
              Tim:
              Actually those unfortunate slips, well described by David, are a HUGE lesson for builders - newbies like me or not. Using such rare foibles as lessons for others is a real credit to David. I particularly value that post because it is a super, super lesson that should be posted on every wall of my newbie shop. Which is exactly what I will do!
