today's work
    • 2641
    #3616
    Have you tried asking FlaredPhoenix? He's done a number of challenging submarine subjects and is available for hire. Not sure of his fees, but might be worth a shout.
    https://www.cgtrader.com/designers/flaredphoenix
    Thread hijack over!
      • 13982
      #3617
Name:	images - 2026-04-09T124037.144.jpg
        I thought you would just cheat the diveplanes control linkages like those on the 1/96 XXI.
          I thought you'd cheat the diveplane linkages like what you did for the 1/96 Type XXI.
            • 13982
            #3620
            I'm still considering it, Romel. ****ing pushrod-clevis-bellcrank-pin nightmare on wheels!!! Damned Britt's!
              • 2641
              #3621
              The x-craft was essentially based on the old Holland craft, shortened and with a simplified hull form to make manufacture quicker and easier.
              So blame the Irish!
                • 13982
                #3622
                  • 13982
                  #3623
                    Kind of strange seeing my old boat. Good job.
                      Hey guys, what’s David have in his refrigerator that is good to eat? Knowing him, a bunch of health food stuff.
                        • 13982
                        #3626
                        DISASTER!
                        Just one final flattened clear-coat away from completion, in seconds I ruined the finish of Jake's 1/72 SKIPJACK class r/c model submarine through shear overconfidence and non-vigilance.
                        I rushed the job; took short cuts.
                        I was too enamored with past accomplishments to regard normal set-up precautions as prerequisites, not options.
                        I over-doped the clear-coat with flattening agent and thinner.
                        I set the touch-up gun with too much product flow and shot the work at too close a distance.
                        And I did the job late at night, a bit fatigued, and should have addressed this chore early the next morning, fresh and alert.
                        I have since wet-sanded away the above waterline portions of the hull and repainted it.
                        Back to square-one because I was an arrogant dumb-ass! Lesson re-learned (yet again!!!)
                          • 954
                          #3627
                          its ok David. Even a monkey can fall out of a tree once in a while...your good.
                            Well, look at the bright side, yesterday was a disaster, but at least you remembered to put your pants on this morning.
                              • 13982
                              #3629
                              Not so fast, Island-Boy!! (early morning, sitting at the computer, still groggy from last nights adventure, looking down to a pair of hairy thighs) ****!
                                Or did you....
