Daily submarine picture
This is a sticky topic.
    Heres a couple of Nautilus photos that you might not have seen before.Click image for larger version
ID:	93340Click image for larger version
      For all you U Boat fansClick image for larger version
ID:	93364Click image for larger version
ID:	93365Click image for larger version
ID:	93366Click image for larger version
        Originally posted by Peter W
        If that is Devonport then they look like Trafalgar or Swiftsure class. If it is Devonport. Looks like a type 23 frigate.
        Peter
        It is Devonport - latest Google shot.
          An interesting shot of Barbel blowing smokeClick image for larger version
Name:	barbel clearing her snorkel mast.jpg
            Notice in this zoomed picture of a Skipjack (Shark), there are no limber holes in the fairing behind the sail on the deck. I wonder why? Any thoughts?
            • Roddersuk
              • Sep 2011
              • 56
              #1881
              I would imagine they aren't there because they aren't needed. If you look closely you will see that the 'fairing' is proud of the hull by at least 1 to 2 inches, and obviously is supported from the underneath. Therefore the water will drain quite readily as required on surfacing.
                They are there, you just got a bad copy of the pic
Name:	uss shark591.jpg
ID:	93474Click image for larger version
ID:	93475check out the flag blowing forwards, underway
                  Oh, somewhat different than on the Revell
                    Disney at its best.Click image for larger version
ID:	97387Click image for larger version
                      What are those towers in the background? Part of a Disney set, or somewhere in Long Beach.
                        good question
                        • KevinMc
                          • 305
                          #1887
                          Support structure for a rain generator?
                          KMc Designs
                            • 13994
                            #1888
                            Painter's scaffolding. It was on rails that permitted it to traverse the background cyclorama (but flat, not concave) for scene change or touch-up.
                              That movie had a lot of location scenes shot in the Bahamas as well as Jamaca. Most of the interior studio shots were at Walt's new studio in Chula Vista, but Disney rented the huge 20th century fox back lot watertank . That back set, stage15 is over 100 ft long just for the sound stage. Half million gallons of water to play with. Jim Camron used it for the Titanic prouction as well.
                                Looks like an Alpha to me.
