Today's work on the little Revell SKIPJACK fittings kit
  • secrtwpn
    • Feb 2012
    • 182
    I received my package today. Workmanship is awesome!. Two questions: 1) It is required to cut out the bottom ballast tank vents on the model and 2) what is "zip cord" ? I'm sure I'll have more as time goes on!
      • 12370
      I'm a GOD!!!!!
      (crack of thunder)
      Anyway...
      .... Yes, open up some flood-drain holes in the bottom of the hull. And punch a hole in the hull duck under the sail before glueing the sail in place, and open up the bridge atop the sail -- all that to vent off the air within the model as you dunk it underwater to flood the spaces around the SubDriver.
      Zip-cord is two-conductor insulated wiring -- use the smallest stuff you can get. Small gauge 'speaker-hook-up-cord' can be found at Walmart and the like.
      Stop talking and start assembling, damit!
      • secrtwpn
        • Feb 2012
        • 182
        Another question:
        Would the SL-6 receiver work in this WTC? And do I need the Shadow Programmer to program it??????
        Gonna start on it this weekend!
          • 12370
          Yes.
          No.
          The Shadow Programmer (not needed by us r/c submariner's) is used with the SL-8 only.
          • small sub guy
            • Dec 2009
            • 45
            Hey Dave,
            I would like to install the mini sub driver into small subs with two screws, are the gears available to convert from single screw to two screw???
              • 12370
              yup.
ID:	68205Click image for larger version
ID:	68206Click image for larger version
ID:	68207Click image for larger version
ID:	68208Click image for larger version
ID:	68209Click image for larger version
ID:	68210Click image for larger version
ID:	68211Click image for larger version
              • small sub guy
                • Dec 2009
                • 45
                Thanx how do i go about ordering two of these motor end caps.
                  • 12370
                  E-mail Mike Caswell (or call him names on this thread .... that'll get his attention!). Tell him you want three of the little 1.25 motor bulkheads, equipped with counter-rotating outputs. He'll bill you, bother me, and we'll get your product underway.
                  What are you going to stick these things into?
                  • small sub guy
                    • Dec 2009
                    • 45
                    In my collection I have:
                    1/144 Gato, 1/350 Kursk, 1/350 Typhoon, 1/230 Lionfish and the 1/72 Type IIA.
Name:	2012-06-05 17.34.50.jpg
ID:	68213Click image for larger version
Name:	2012-06-05 17.29.07.jpg
                    Working too many subs need to focus on one.
                    this one is based on your Type VII. Yes that wtc fits in that 1 inch opening.
                    • vital.spark
                      • May 2010
                      • 276
                      Mike and David, I want the little 1.25 motor bulkheads, some equipped with counter-rotating outputs including the lpb's. Bill me, bother David, and get the product underway. You have put this off for too long!
                        • 12370
                        Ha!
                        I have yet to perfect the ballast system, Myron! Sure, we'll sell you the motor bulkhead with two counter-rotating outputs, but the rest is up to you. Game?
                        • secrtwpn
                          • Feb 2012
                          • 182
                          What size rod did you use with the screeding tool?
                            • 12370
                            1/16" brass rod.
                            • secrtwpn
                              • Feb 2012
                              • 182
                              In a week (when we are back from vacation) I'm gonna start the reshaping of the bow. Any other substances besides the Evercoat (such as Milliput) that would work. I'm not familar with the Evercoat line. And any suggestions how to do it.......
                                • 12370
                                If I ment Milliput, I would have SAID Milliput.
                                Too stiff!
                                I said to use one of the Evercoat two-part fillers for a reason!
                                That reason is the very smooth, easy to spread, nature of the stuff!
                                Mr. Caswell caries it, I recommend either the Evercoat Metal Glaze or Rage.
                                Get hoping!
                                Don't make me come over there!
