Akula 1/144 Scratch built
    • 3705
    #241
    The detailing and crisp scribing are amazing! You are a machine!
      • 13831
      #242
      Originally posted by bwi 971
      That will be GREAT David, looking fwd to it!!
      I'm finishing on the research.......I'm struggling (lack of info) with the underwater part of the sub......but I'm getting there......I will assume flood holes would have been ALFA wise.
      Is Wayne Frey still around? If so can how can I contact him?
      Grtz,
      Bart
      Get to me what you got when you've completed your research on that slick looking little race-horse of a submarine. I lost touch with Wayne about the same time me and the SC engaged in a very ugly divorce. Can't help you with that guy. I do cruise the forums, and I have not seen any activity from him since those dark days. Once he got back from Russia (by the skin of his teeth) he pulled a Snowden on us.
      • bwi 971
        • Jan 2015
        • 940
        #243
        With exeption of the railing and safe guard all parts are on.......next up is the transportation box and in water trimming.
        "Samuel Smiles"
          • 13831
          #244
          What an accurate and crisp job you did of the scribing. Oh, almost forgot ...
          ... I HATE YOU!
          • vital.spark
            • May 2010
            • 311
            #245
            All I can say is Magnificent!
            • bwi 971
              • Jan 2015
              • 940
              #246
              Thks
              WIP on the transportation box.......I made it almost exactly as per David's guideline I found on the forum (monkey see monkey do). http://forum.sub-driver.com/forum/ge...96-seawolf-kit post #4.
              "Samuel Smiles"
              • bwi 971
                • Jan 2015
                • 940
                #247
                Fabricated securing arrangement upper and lower hull
                Connected fwd dive planes
                Finished transportation box, every compartment is provided with his own vent holes
                Yes on the pictures the towed array pod is not in line with the centerline of the sub....don't worry she is not yet fixated.
                Will do some IW trimming this evening.
                Grtz,
                Bart
                "Samuel Smiles"
                  • 3705
                  #248
                  Bart,
                  You are a craftsman. From that outstanding Akula to the box it is being put in, you show a great ability that surpasses most of the RC submariners out there (myself included). You are an inspiration.
                  tom
                  • bwi 971
                    • Jan 2015
                    • 940
                    #249
                    Bart,
                    tom
                    Thks Tom......aw-shucks smile
                    grtz,
                    bart
                    I forgot to mention it is all David's fault....he made me do this.
                    "Samuel Smiles"
                      • 13831
                      #250
                      Tom: I was getting ready to delete your fawning and lip-stick smeared love letter to Bart. But, as I once again scrolled through his primer-gray AKULA pictures I found myself nodding in agreement with you. Therefore, I permit you to live yet another day.
                        • 3705
                        #251
                        Thank you HWSNBN, (bowing low), I am thankful for every day I am given. I will also discontinue the use of lipstick, although I did like that shade.
                          • 13831
                          #252
                          (busily scrubbing brain with Drano ... attempting to delete awful imagery!)
                            Great job Bart; if only it hadn't involved Tom wearing lipstick...........
                            • bwi 971
                              • Jan 2015
                              • 940
                              #254
                              And how I'm supposed to get some sleep without terrible nightmares…..Even when Starring at the water in the bathtub doing trimming work I see Tom’s reflection THKS guy’s…..this will take a while to fade.
                              A quick in-between WIP
                              Empty ballast;
                              Put as much weight in her as I could add foam. Had to put the foam all the way up to the waterline to get her stability right. It's very good now, self-righting is very quick, she is very stable in the water.
                              In ballast:
                              was almost perfect without doing anything......her ass was slightly to light......she was floating on the towed array pod, I have to make the towed array pod free flooding…..good thing I didn’t glued the sucker in place yet.
                              Grtz,
                              Bart
                              "Samuel Smiles"
                              • bwi 971
                                • Jan 2015
                                • 940
                                #255
                                A live WIP,
                                Pod is free flooding now.....in ballast trim is good....although I'm not able to blow the ballast tank empty.....will do some investigation by elimination of possibilities.
                                grtz,
                                Bart
                                "Samuel Smiles"
