Akula 1/144 Scratch built
    #226
    Yep........I will do some more scribing today Tom,.....when all scribing is finished I go around with the red glazing putty :-)
    Grtz,
    Bart
      #227
      YES scribing is all done.......left the most difficult for the last the fwd sonar dome. I spent quite some time on that thing. Needed all my skills to get the job done. Curved lines to show up as straight lines, tight radiuses on curves surfaces.
      Used tools,the stencil (most left) is made of 0.15mm brass sheet and cut with exacto knife.
Name:	Akula (712).JPG
      Work in progress
Name:	Akula (716).JPG
      Sonar dome all scribed, the seem of the lower hull is integrated in the scribing lines of the sonar dome. yes I planned it like that when I made the cut, eand I think it worked out fine.
Name:	Akula (715).JPG
Name:	Akula (707).JPG
Name:	Akula (708).JPG
Name:	Akula (713).JPG
      Red glazing putty here I come,
      Grtz,
      Bart
        • 13982
        #228
        Well done, sir!
          #229
          Well done, sir!
          Thank you sir
          Did some work on the towed array pod.
          • Touched up all deficiencies with red glazing putty,
          • Recessed the vent gratings
          • Made the hole to take the light (diameter 2.2 mm ; 5/64")
          • Glued the fwd acces hatch in place (brass diameter 4.5mm)
          I’m very pleased with the look of the gratings, It is all worth the work I put into making them. Will I do it again? Yes I would.
Name:	Akula (721).JPG
Name:	Akula (719).JPG
Name:	Akula (722).JPG
          Grtz,
          Bart
            #230
            I'm adding the detail bits and pieces to the hull.
            The gratings are all in place now, glued with CA.
            The single action airbrush for painting is ordered ( wider patterns of up to 1-1/2 inches)
            The sub will be ready for painting when the airbrush arrives from the USofA.
            Grtz,
            Bart
Name:	Akula (729).JPG
Name:	Akula (725).JPG
Name:	Akula (730).JPG
Name:	Akula (726).JPG
Name:	Akula (723).JPG
              This project looks like its good enough for filming "RED OCTOBER 2". Good Job Bart!
                #232
                Originally posted by HardRock
                Don't they have grub screws wher you live!
                I received 100 pc of M2 grub screw today....I hate you.
                Grtz,
                Bart
                  #233
                  Casting
                  I gave it a thought while making the molds for the small stuff, and some of you will have thought the same and were too polite to tell me (you’re getting soft HWSNBN).....IT WILL BE DIFFICULT TO REMOVE THE PARTS FROM THE BIG ASS FOUNDATION (I have been told this is the appropriate name for it).
                  Well I was right about it and so were you……...............so I did the molts all over….........and now they are perfect ......…..damn I’m getting good @ this stuff.
                  I made stand-off pieces for all the parts so I can snap them off from the big ass foundation easily after casting.
                  The trick and exercise is to design them so they do not affect the quality of your cast……you need the part to come out perfect not with deficiencies (air bubbles, partly casted,…..).
                  Below you see the difference between old and new and some overall pictures.
                  Grtz,
                  Bart Click image for larger version
Name:	2016-08-26 08_39_13-Akula (548)002.jpg
Name:	2016-08-26 08_43_45-Akula (741)003.jpg
Name:	2016-08-26 08_46_22-Akula (742)001.jpg
                  Picture below: on the right you see the mould for the lights in curing process.
Name:	Akula (746).JPG
Name:	Akula (745).JPG
Name:	Akula (744).JPG
Name:	Akula (743).JPG
                  Last edited by bwi 971; 08-26-2016, 02:02 AM. Reason: adding explanation to one picture
                    • 13982
                    #234
                    Excellent presentation, Bart. Showing the screw-up gives perfect context to the 'improved' tool. Great photography and the call-outs makes the discussion crystal clear. Good stuff, sir (I now secure from nice-mode, and run to the kitchen to kick the cat).
                      #235
                      Some minor touch up to do......but she looks FANTASTIC already……now a little more modest I think she looks OK.......F*CK IT.......she looks FANTASTIC, INCREDIBLE, AWESOME,......
                      Grtz,
                      Bart
Name:	P1040309 - kopie004.jpg
Name:	P1040308 - kopie003.jpg
Name:	P1040310 - kopie005.jpg
Name:	P1040313 - kopie007.jpg
Name:	P1040312 - kopie001.jpg
Name:	P1040311 - kopie006.jpg
                        • 13982
                        #236
                        I agree with you completely -- stunning work. God, it looks like it's doing 40 knots just sitting there. Those appendages (so many pointy thingies) really do a lot to enhance the 'menace' and purpose of the boat.
                        I want one! Who do I have to kill to get a kit of this thing?
                          #237
                          first I cona make you a Beluga project 1710
                          Beluga scale 72 LOA x Beam 889 x 125 mm 35,0 x 4,9 inch
                          the SD is fantastic David I had it in the water yesterday
                          Some lead and foam required to get the Akula stable in the water (top heavy)…….but the SD is giving me plenty buoyancy to play with.
                          The SD alone is laying in the the water at almost even keel.
                          Grtz,
                          Bart
                            • 13982
                            #238
                            Grtz,
                            Bart
                            I want to play too!!!!!
                            How about I do the propeller master for you, as well as the tool and some cast white-metal propellers? And any other appendage parts you may entrust to me to make -- when done I'll send you back the master(s), tool(s), and some parts.
                            Send me the documents relevant, and I'll get to work.
                            BELUGA?!!! ... I like it! Be the perfect companion to my 1/60 ALBACORE.
                              #239
                              That will be GREAT David, looking fwd to it!!
                              I'm finishing on the research.......I'm struggling (lack of info) with the underwater part of the sub......but I'm getting there......I will assume flood holes would have been ALFA wise.
                              Is Wayne Frey still around? If so can how can I contact him?
                              Grtz,
                              Bart
                                Im in complete agreement with David. It doesnt look scratchbuilt..........it looks machine made! I am very impressed Bart!
