Stingray Build
    • 13390
    #106
    I totally agree with you. Helps keep the knock-off Pirates at bay.
    • RCnut
      • Apr 2012
      • 441
      #107
      It will not stop the hardened re casters but at least its out there and known to be mine, Part of the reason I do all this posting now. Not like a lot of people will not know who mastered this now. wont stop it but hell, you gotta try.
        • 2403
        #108
        Only way to stop your work being copied is to not sell any!
          • 13390
          #109
          Good move -- the best poor-man's copyright is to get the word out amoung the leaders in the field. We'll deal with any knock-off crook we come across here in the State's.
          My policy: Re-casters are killed and eaten on the spot!
            UM.................do they get any last requests?
              • 2403
              #111
              Perhaps they can choose to go in the cube?
              • RCnut
                • Apr 2012
                • 441
                #112
                Well the way I see it is that this model build was posted on 4 different forums and facebook. Most people will know its mine and thats all I can expect. On a lighter note the moulds for the resin parts have been done apart from the large top fins, ran out of rubber. More coming on wednesday so will do the rest then. hope to get a pull over the weekend.
                  • 13390
                  #113
                  HA! Someone got it!
                  I hear Caswell will soon be stocking bulk Razor-wire. When not modeling I tinker with Trap design.
                    • 13390
                    #114
                    I say again: You are a machine!
                    • RCnut
                      • Apr 2012
                      • 441
                      #115
                      Lol sometimes I wish I was.
                      • RCnut
                        • Apr 2012
                        • 441
                        #116
                        Last pic of masters before the first pour of rubber. The white walls are simply to hold in the neat rubber and build up a solid edge, after 3 pours of neat I add a thixotropic agent and butter the rest on.
                          • 13390
                          #117
                          By 'neat' I assume you mean first applications of RTV straight out of the can, thin -- to minimize bubble entrapment, then build up with thickened rubber? What nominal wall thickness to the glove element do you shoot for?
                          Will you make a rigid 'mother-mold', or backing strong back to back up the rubber tool against the sagging that results from gravity and such?
                          I got permission from the originator of the smaller resin STINGRAY to make my own tool for a GRP copy -- here's how I did it. The brown stuff is the gel-coat and glass lay-up done to creat a backing mother-mold. It worked but if I had it to do over again I would have made the rubber element (the glove mold in local language) thicker.
ID:	68007Click image for larger version
ID:	68008Click image for larger version
ID:	68009Click image for larger version
ID:	68010Click image for larger version
ID:	68011Click image for larger version
ID:	68012Click image for larger version
ID:	68013Click image for larger version
                          • RCnut
                            • Apr 2012
                            • 441
                            #118
                            Yup, the only difference here is tha your making a two part mould (From what I see) I have it a bit easier as mines in two parts. My Sky1 is done as you have shown there. My Glove will be made of Fibreglass for strength. Oh BTW First pour is on.
                            • RCnut
                              • Apr 2012
                              • 441
                              #119
                              There you go.
                                • 13390
                                #120
                                Yeah, had to make a parting mold-board as I was dealing with a full-up hull casting. Great minds think alike. You're already deep into the rubber end of things. Wow. I better get hot on that PJ valve I bragged about above ...
