Continuing/finishing (?) a Revell 1/72 type VIIC from another user
    • 13697
    Nothing indicated on-model as to waterline. Your booklet that comes with the kit indicates it, I think. Use a surface-gauge to mark it off.
    But, don't paint anything till you have this thing running right in the pool. Then we'll talk painting.
    • Reckless
      • Jan 2012
      • 183
      yeah wasn't intending to paint yet... just busy brain while waiting for things to set, etc... trying to keep planned ahead and such. .. that and I don't want a nicely painted underwater war machine... with bright pink showing through the holes and vents.. ha!
      either way.. the project marches along as a sorta steady pace... defiantely taking this alot slower then any of my surface boat stuff :D
        • 13697
        Thinking ahead. I like that. Bet you're good at pool. Keep at it.
        • Reckless
          • Jan 2012
          • 183
          hehe... my friends won't play with me anymore....
          haven't quite got the swing of chess yet though ... not enough people still play it around here... and the online stuff thus far sucks.
          I had hoped to have the rods done today.. but I had to flash sell my last airsoft gun to make sure kids school payment didn't bounce .. so I've spent the day getting the airsoft gun ready to hand off instead of working on my RC stuff
          with any luck I'll find out tommorow I have a new job...
            • 3673
            I'll keep you in my thoughts on the job!
            Cheers,
            Tom
              • 13697
              You put first things first, Reckless. I like that.
              • Reckless
                • Jan 2012
                • 183
                .. I dunno.. think it'll be enough? ... LOL
                1 full 1/2inch sheet, and 1 full 1inch sheet... each cut into 4 pieces so I could bring em home in the car...
                nothing definate newjob wise for the rest of this week ... so.. with ANY luck the sub will hit the domestic test tank for first foam testing by friday...
                • Reckless
                  • Jan 2012
                  • 183
                  bah... just realized I have to wait for the new 75mhz FM module for my radio (I hope I ordered the right one.. LOL ) before I can properly do the pushrods (servo's activated in neutral position, etc) , and testing (flooding balast for foam ) and such.... unless I flip out for my 2.4 for the sake of testing
                  • Reckless
                    • Jan 2012
                    • 183
                    well ... I gots me a new job... start next monday... that's the good news.... the bad news is still haven't received the new module I ordered for the radio I got my hands on .... so I haven't been able to progress on good concious (I don't wanna find out the servo's weren't zero'd and require remaking the pushrods )
                    so at this moment I'm in a holding pattern... good ole hurry up and wait.. LOL
                    • Reckless
                      • Jan 2012
                      • 183
                      finally got the damned module for my radio today :D hope to have the SD powered up for the first time in my possession tonight... .. make sure the servo's are centered, then finally build the pushrods ... so I can trim the beasty and finally get it wet :D
                      • Reckless
                        • Jan 2012
                        • 183
                        built my first set of pushrods... and the brass rods I used are too thin, they are flexing all over the place.. they fit the klikons well, but they flex
                        and I have to figure out a way to tighten up the lever on the rear planes... it's flopping all over the place :(
                          • 13697
                          Take the cast white-metal 'lever' -- its proper nomenclature is, 'stern plane bell-crank' -- put it on an anvil and smash it with a hammer.
                          Lightly, though.
                          This will reduce the size of the square hole in its center. You repeat the terrible hammer blows till the square section stern plane operating shaft is an interferrence fit within the hole. That will take the slop out of the system.
                          Hammers are our friends!
                          • Reckless
                            • Jan 2012
                            • 183
                            .... what is this... lightly, you speak of? ...
                            :biggrin:
                            can this be done after it's all be put together? LOL ... I dunno if it'll come apart without breaking something.. as in .. I dunno what Ire glued/locked inplace before hand...
                            eh... I'll figure it out... .. but progress is being made... things are living and moving... the great fun will be to see if the SD is still sealing up ..etc... heh..
                              • 13697
                              Either both or one of the stern planes should only be a friction fit to the square sectoned operating shaft -- this permits you to pull the operating shaft out of the square hole in the bell-crank, permitting removal of the bell-crank out of the skeg so you can perform the hammer trick.
                              • Reckless
                                • Jan 2012
                                • 183
                                #30
                                the stern planes are glued to said rod... I tried several ways and forms to pull or pry them off .. ain't no friction fit LOL ... so I gotta figure that out... probably a cut and rebuild
                                but I made some progress and got the rods finalized
                                getting closer!
