GATO! (It has begun)
  • matthewnimmo
    • Dec 2011
    • 271
    So, as posted earlier on I think trout's thread of being scared ****less about taking on this challenge with his build (after seeing his troubles), I've decided to carry on with my build anyhow. I officially started on the 1st of this year with cleaning downstairs to prep for the area that I'll be working in. Below are the first pictures of the sub's hull being assembled.
    The hull didn't have too much of a bow in it, so that was a nice surprise. This morning I removed the tape and finished gluing those areas. Tonight I should have some time to continue:)
ID:	101551Click image for larger version
    • 3746
    Welcome again and I look forward to your build! Glad you took the plunge....at times you may not think that you are glad, but keep an eye at the finish line - which is what I am doing. And if you can learn from my mistakes (and I do a lot of them) then my posting has served a purpose. Class has begun....
      Great! Another builders thread! I hope that you do well, and we will be watching with great interest. Welcome!
      • matthewnimmo
        • Dec 2011
        • 271
        @WHomever:
        So, reviewing the video that has been included with the kit (yes, i've watched them all before even starting and going through them a 2nd time as i go through the model), I've noted some of the products needed to complete this sub. One of those products was the putty that David mixed (blue stuff) and filled in any holes/etc with. That stuff sets up in like 5 minutes correct? Well, were can i find it? Any place that is well known like a Lowe's/Home Depot (think it automobile related so i don't think i'll find it there) that i can get the stuff at?
        Also, i was looking at the testors "model putty" that one might see in a grey tube beside the red tube of model glue at any Hobby shop; but was wondering how fast does that stuff dry as it doesn't say...anyone used that before?
        Thanks,
          • 13973
          Hobby shop primers, paints, adhesives, putties, and fillers are designed to be safe, not useful. Get your filler and Nitro-Stan from your local automotive refinishing supply house.
          Caswell sells the Evercoat line of fillers -- buy there FIRST, damit!
            • 3746
            matthewnimmo,
            You can get Evercoat here: http://www.caswellplating.com/aids/evercoat1.html or google it. I have not used testers "model putty" (if it is the one I am thinking about) in years, no decades....no help there.
            In one of David's Cabal reports, he says that bondo is fine....David do you still stand by that? I have also been told that the Easy Sand will work as well (a little more economical).
            Tom
            • matthewnimmo
              • Dec 2011
              • 271
              LOL...alright, got it ... so i'm assuming that the Poly-Flex is what i need to get as that's what you used a lot of in your video's David? The other stuff from that link, i don't think i need for this model?
              Actually, while i'm at it (and i don't mind getting the stuff from caswell if they have all that i need) the acid needed for the white metals and any of those other products as david mentioned that i'd need for this model? Is there a sticky on the forums for these products?
              • beeryboats
                • Jun 2011
                • 124
                Welcome! Let the fun begin. I got the Rave filler from Caswell and it works great, and fast! It's kinda neat that it will go to a puddy state that lets you trim it with a blade before it sets. One other tip is don't screw up like I did on cutting the hull apart. Find the right cutting wheel and goooo sllooooww.
                Jay
                  • 13973
                  Get the Rage filler, good stuff. Poly-Flex is fine, but I only used it because it was at hand. Use the stuff I use and you can't go wrong.
                  • matthewnimmo
                    • Dec 2011
                    • 271
                    That's exactly what i'm going to do David.
                    1) rage stuff for most of the work it seems (the blue puddy in the videos i'm assuming)
                    2) did you use the metal stuff at all for the white metals in filling in the bumps/etc?
                    3) also, for getting the white metals ready for smoothing out with the above stuff in number 2. Can i use vingar to soak them in? If so, how long would you suggest?
                    Thanks again!
                      • 13973
                      Only use putty, filler and primer on the white metal after it has been pickled.
                      The ideal acid is the diluted Ferric Chloride you get from an electronics supply house -- used to etch metal clad circuit board material. If that's not available, then soak the work in vinegar overnight, or warm up the vinegar and soak the work in it as you agitate it occasionally. The Ferric chloride works in seconds, the vinegar takes hours.
                      Rage is perfect for our work, but the other two-part fillers offered by Evercoat will do.
                      Metal stuff?
                      Stop screwing around, let's assemble this thing!
                      • matthewnimmo
                        • Dec 2011
                        • 271
                        lol...i plan on doing more work on the model tonight, just trying to get my ducks in a row before hand with these consumables.
                        So, found some evercoat rage ... but every autobody supply place just looks at me like i'm crazy when i ask about Nitro-Stan. So, few questions about that stuff.
                        1) I think i know the answer to this; but going to plead ignorance anyhow. Why use this stuff over the rage? don't they do the same thing? I think the answer is that the nitro is quick to apply and used for small spots (but maybe i'm wrong).
                        2) I can order the stuff online, which i may just do; but is there an equivalent to that stuff that I may have an easier task of finding locally?
                        Thanks,
                          • 13973
                          The Nitro-Stan is an air-dry, lacquer based toch-up putty goof for only filling scratches and the like. You use the two-part Evercoat filler (your kit of Rage) for re-contouring and seam filling jobs.
                          I think the 3M red touch-up putty (some box stores have the stuff) is pretty much the same formula as the Nitro-Stan. Check it out.
                          Hobby-store putties are crap.
                          Go get 'em, Tiger!
                          • ADDINGTON
                            • Sep 2008
                            • 80
                            David made me a Nitro-StanFan long ago, right about the time I was throwing all of my Bondo products into the workshop circular file.
                            I have no 3M experience but recently was pressed to try the 'Bondo' Glazing Putty on styrene and it was suprisingly good, virtually all the qualities I get from NS. There's nothing like the good stuff, but this isn't bad at all, and easy to find.
                            -Kerry
                            • matthewnimmo
                              • Dec 2011
                              • 271
                              Progress:
                              Last night I assembled the bow, I had to use some tape as these pieces were slightly warped and not fulling touching for a good weld. This morning I removed the tape and finished off the weld as everything turned out well from last nights drying. I should be cutting out access points within the bow tonight.
ID:	65862Click image for larger version
ID:	65863Click image for larger version
ID:	65864Click image for larger version
