My Projects
    • Jan 2020
    • 1036
    #91
    Photo showing bow endcap detached
    Click image for larger version  Name:	Image 11-14-25 at 7.07 AM.jpg Views:	0 Size:	55.9 KB ID:	191730
      • Jan 2020
      • 1036
      #92
      more photos
Name:	Image 11-14-25 at 6.52 AM 2.jpg
Name:	Image 11-14-25 at 6.51 AM 2.jpg
        • Jan 2020
        • 1036
        #93
        more photos
Name:	Image 11-14-25 at 6.49 AM 2.jpg
Name:	Image 11-14-25 at 6.48 AM 3.jpg
          • Jan 2020
          • 1036
          #94
          more photos
Name:	Image 11-14-25 at 6.48 AM 2.jpg
Name:	Image 11-14-25 at 6.47 AM (1) 2.jpg
            • Jan 2020
            • 1036
            #95
            Starting the assembly. Total Resin used 557ML, total print time 28 hours.
            Click image for larger version  Name:	IMG_0195.jpg Views:	0 Size:	54.8 KB ID:	191858
              • Jan 2020
              • 1036
              #96
              Latest revisions to cylinder.....
Name:	Image 11-26-25 at 6.21 AM.jpg
                • Jan 2020
                • 1036
                #97
                Starting at the stern, first 3 sections attached with screws and threaded inserts. Motor attachment threaded inserts installed, pump, pump esc, and rx layed in.
                  • Jan 2020
                  • 1036
                  #98
                  So I want to eliminate the crimp in tubes that attach to this pump, so made "180 degree manifolds"
                    • Jan 2020
                    • 1036
                    #99
                    So as I finish the cylinder, thinking about what boat to put it in. Have never printed a sub in resin so decided to test print Bobs 212 Tail Section at 1:70 scale, came out nicely
                      • Jan 2020
                      • 1036
                      #100
                      Doing some electronic wiring and designing electronic compartments on tray
                        • Jan 2020
                        • 1036
                        #101
                        Ok, cylinder is complete, pressure tested and fully functional. Working on new bow end caps for better bow servo alignment.
                          • Jan 2020
                          • 1036
                          #102
                          With the Cylinder completed and fully tested, I am now building the German Type 212 STL files from The Nautilus Drydocks in 1:70 Scale. For easy placement of the files I like importing them at 25% scale to Tinkercad
                          Click image for larger version  Name:	Image 1-15-26 at 8.14â¯AM.png Views:	0 Size:	21.1 KB ID:	193184
                            • 965
                            #103
                            Make sure the End caps are of a material that will not become porous and absorb water. Maybe you already have checked. If its printed material, refer to posts in this forum on this topic.
                              • Jan 2020
                              • 1036
                              #104
                              The are printed with Siraya Tech Fast ABS-Like 3D Printer Resin. I will monitor for absorption. On the next one we are going to coat them.
