My Projects
    • 3429
    So both shaft from the WTC are angled out / \
      • Jan 2020
      • 1006
      that's correct
        • Jan 2020
        • 1006
        Replaced the hatch, fixed tail seam and hull seams. Anchor arrived from Australia. Click image for larger version
ID:	186174 Click image for larger version
ID:	186175 Click image for larger version
          • 1536
          I need to get a printer to do that boat in 1/96 as a display.
          • wlambing
            • Nov 2020
            • 381
            That is not the correct anchor for Nautilus, or any other USN ship. Yes, I'm a rivet counter, having served for 23 years and, I have the 1:1 scale Nautilus parked just a few miles from where I sit now. I don't know what the actual specs are for the hook, but a USN anchor for a WWII destroyer in the same scale should work. What you purchased is a European anchor. Model Monkey (Steve Larson) makes nice 3D printed stuff. Good luck!
              • Jan 2020
              • 1006
              You are correct!
                • Jan 2020
                • 1006
                Epoxied the windows, need to clean up the sail, guess I will have to have light behind them along with navigation lights, Click image for larger version
ID:	186188 Click image for larger version
                  • Jan 2020
                  • 1006
                  Designing upper hull hold down to tail Click image for larger version
                    • Jan 2020
                    • 1006
                    Moving on to installing forward servo and electrical wires for lights Click image for larger version
                      • Jan 2020
                      • 1006
                      " Click image for larger version
ID:	186254 Done with this guy"
                        • Jan 2020
                        • 1006
                        Forward Servo and navigation lights installed Click image for larger version
                          • Jan 2020
                          • 1006
                          Trimming the boat Click image for larger version
                            • Jan 2020
                            • 1006
                            So, it took days to get her trimmed, at one point I ripped most of the weights and foam out. She is now trimmed for fresh water, will change a bit in saltwater. I primed her again. Due to sizing the files down so much and the layer orientation she is splintering on the outside, I covered the inside with fiberglass, we'll see.... Click image for larger version
ID:	186739 Click image for larger version
                              • Jan 2020
                              • 1006
                              5:1 Light Sea Grey to Sea Grey Click image for larger version
                                • Jan 2020
                                • 1006
                                #30
                                A bit of weathering Click image for larger version
ID:	186766 Click image for larger version
