Surprize! Surprize! :D
Today all reciever channels are doing what they're supposed to. I guess the Grimlins had enough fun with me yesterday and desided to take the day off. ;)
I'm still getting a little servo jitter when the drive motors are running but that seems to be normal with all the electronics wadded up in those tight little SDs.
I try to route the ESC and motor wires away from everything else, but in that tight space they sometime end up close to each other, causing cross-talk signals, which is what I think the problem is.
I Hate having to run the antenna wire past the motors, but it has to go out the same end-cap. I may try to shield the antenna (with grounded shield sleeve) inside SD and see if that helps any?
I never had all these problems with my Surface Ships! :)
